Question about Bosch Power Tools Chop Saws
Ihave a bosch proffessional 18v li. the chuck wobbles, I have had the gear box and chuck replaced under warranty, and it still does same am I wasting my time? Has anybody else had this problem?
    President:
  • 2,220 Answers
Miss catagorized post.
Posted on Feb 18, 2010
Can I buy a battery charger for a ozito drill
yes
Search Results
Ozito Power X Change 18V Eco Battery Charger Tool ' Bunnings ...
https://www.bunnings.com.au > ... > Cordless Accessories > Batteries & Chargers The Ozito PXCG-120 18V Eco Charger can be used to charge any of the Power X Change battery packs and includes a charge indication. The Power X Change Eco Charger is a compact and portable design. Charge Time: 1.5Ah Battery - 2.0hours 2.0Ah Battery - 2.5hours 3.0Ah Battery - 4.0hours 4.0Ah Battery - 5.0hours
Batteries & Chargers available from Bunnings Warehouse
https://www.bunnings.com.au/our-range/tools/power-tools/.../batteries-chargers Compare. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. 79. Compare. Ryobi One+ 18V 1.5Ah Lithium+ Battery. Ryobi One+ 18V 1.5Ah Lithium+ Battery. 69. Compare. Bosch Blue 18V 3.0Ah Li-Ion Battery. Bosch Blue 18V 3.0Ah Li-Ion Battery. 119.‎Ozito Power X Change 18V ... · ‎Ozito Power X Change 18V Li ...
Dec 02, 2017 | Drills
Hi my driver seams to work fine but I can hold the ***** bit still with my fingers as it unpacks. so barely starts to push screws in.
That sounds like the clutch is slipping. How old is this unit? I found this site on the warranty it says it has a three years. https://www.bosch-professional.com/gb/en/service/warranty/warranty.htm
Mar 28, 2016 | Bosch Gdr18v-Li 18V Cordless Li-Ion Body...
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
My macita imp li-ion 18v chuck slipps
You may have a broken gear in the gear box or a broken output shaft. In either case you need to have it repaired or replaced.
Jan 21, 2015 | Drills
Replacing brushes Bosch impact driver
If it has the replaceable brushes it should be no problem, just unscrew and replace. Try oasistools.co.uk
Dec 28, 2012 | Bosch Gdr18v-Li 18V 2-Speed Multi-Function...
I,m having trouble getting the chuck off my 13618 bosch 18v hammerdrill. I have removed the screw then chucked a piece of hexed stock into it and reversed a half inch impact to it and it won't bre
Make sure it is in low gear on drill mode. try with just a bar in the socket and hit the end to shock it. This is sometimes better than a constant force.
Nov 21, 2012 | Bosch 13618 - 2G 18V Brute Tough Cordless...
I have a makita BHP451 drill/driver with a keyless chuck and the gear box has striped out. I have a new gear box but do not know how to get the chuck off. I see a slot in the chuck that looks like you my...
The chuck has a left hand threaded screw inside. Turn to the right when removing the screw. Once the screw is removed you can remove the chuck by turning it to the left as it has standard, right hand threads. It is easiest to insert a large, L shaped allen wrench into the chuck, tighten the chuck, and hit the wrench with a hammer to spin the chuck off.
Jul 11, 2011 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Replacing gears
you have to disassemble the tool completely. Remove chuck, remove battery, remove all screws holding body parts together, remove one side of body. Now you can see motor and gear box. Pull out both of them and twist gearbox a bit (just few degrees or millimeters) if it goes, then just pull gear away from the motor. Be carefull, some gear parts may drop of, so hold gearbox down and motor up. Juraj
Jun 04, 2010 | Makita 18V 1/2"CRDLS Drill Kit
The chuck is stuck open
see www.ereplacementparts.com / www.partsdirect.com / www.dewaltservicenet.com for parts & cost.gears are stripped in the chuck so new replacement. check date code of your drill they might repair it under warranty.
Aug 25, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Bosch Power Tools Chop Saws Logo
95 people viewed this question
Top Bosch Garden Experts
roeb
cwradio73
Are you a Bosch Garden Expert? Answer questions, earn points and help others
