Question about Futaba Toys
FP-T7FG/k channel 6 (flaps ) switch on tx doesnt move servo
FP-T7FG/k channel 6 (flaps ) switch on tx doesnt move servo . if direction switch in tx rear panel is changed from normal to reversed ,servo moves to a preset position i.e. servo is live but front panel tx switch not working.Seems like it is all working but the pot switch doesnt change the servo position - pot problem ? Broken wire on switch pot ? cant see how to remove circuit board to get at switch pot . seems to be a fixing (cant see it ) under the central small RF board stopping the main board comming out How do I remove the main board to get at pot switch?.
  • 7 Answers
SOURCE: What plug goes where in
you havt to put the plug in the back of it and then putit in warter swicth th roster battery with plug dk
Posted on Dec 21, 2008
SOURCE: Low volume on front pickup of Epiphone Les Paul
i have an old sg, and this happened to me too. the repair guy told me that inside the p/u, the windings were broken, resulting in a lower output. go on e-bay, and look up a neck pos. humbucker. there everywhere. or do yourself a favor, and do what i did. i have an epi. flying v, and epi. les paul. on e-bay, i bought gibson 57 classics. i put these in both my guitars, and i now have great sounding guitars. you will not belive the difference. good luck, scott
Posted on Apr 08, 2009
SOURCE: only goes in reverse after recent charging
I would replace the high/low switch and the reverse switch.
I had the same problem of it not going forward, but I just replaced the high/low switch. It turns out 1 month later I had to replace the reverse switch.
Here is the link to the site that I found my switches on.
Hope this helps
Posted on Apr 21, 2009
SOURCE: two broken gemmy dean martin dolls how can i get them fixed
i looked through my local yellow pages and called a few electronic repair places. i finally found someone willing to take a look at it. sure enough they were able to fix it.i picked one up today and dropped the other off to see how they could do with this one now too.thanks you dolores metacarpa
Posted on Jun 17, 2009
  • 111 Answers
SOURCE: flashing prnds with 17090 error code
punch this code into google search and research the answers that show similar symptoms
Posted on Sep 13, 2009
What and where is the servos
  • A servo is a mechanism, usually a motor of some sort, that drives another mechanism. On a passenger aeroplane, for example, the control surfaces are too difficult for the pilot to operate because there is so much wind pressure against them, so they use hydraulic servos to move the elevator, flaps etc.
  • On a car, the drive by wire throttle control is a servo, which is electronically controlled by the computer, depending on the throttle position under the driver's foot.
  • In effect, the power steering ram on a car is also a servo, which is powered by the p/s pump, and controlled by the valves in the steering column.
  • On a smaller scale, the air conditioner has servos that open and close the relevant air duct flaps when the dashboard controls are shifted to control the flow of air in the car. Please note that on older cars, and some new ones, these flaps are not controlled by servos but by cables.
  • The remote controlled central locking on a car has servos in the doors that open and close the door locks when the remote button is pressed. On some cars these door lock servos are small electric motors, on others they use vacuum operated pistons, also called servos.
  • Hope this answers your question!
Feb 16, 2015 | 1999 GMC Jimmy
Iv'e just brought a TX-47AS470b and the speech is not matching the lips is there any thing that I can do?
Is that occurring on every channel? Sometimes that happens on my digital TV that I have a cable line plugged directly into it. The is one channel that displays its content, and when I press the remote to move ahead two channels, the same content comes up again (only on that one, the lip movement does not match the audible dialog; so I switch back to the other channel and its fine. Unfortunately, that is not a TV issue, its a broadcasting issue.
Nov 24, 2014 | Televison & Video
My Cobra CB Radio Receives Fine But No Transmit
is it a total no TX. or just not getting out very far.?
could have a broken mic wire. or the CB / PA switch may be in a wierd spot try moving it.. are you getting the Correct RX frequency on the channels.. ie are you getting channel 20 on acutal ch 20. and if you switch to ch. 6 are you getting ch 6? if you could explain more..
Dec 11, 2013 | Radio Communications
1999 Lexus RX 300 clicking sound below glove box on AC system
If you take the glovebox out, you can see the air inlet servomotor on the left side of the blower housing. (SEE DIAGRAM)
This is very likely to be what you are hearing. This is a quite common problem. This servo is electronicall controlled. When the HVAC is turned on, the servo is supposed to go through a "full swing" to test itself. Many times, things (papers, napkins, drinking straws, etc.) from an overflowing glove box get jammed in the recirc-air flap right behind the glove box. when this happens, the servo cannot make a full swing and sometimes it damages the servo, which continues to attempt the full swing and keeps clicking because it is stripping its internal gears trying to make it happen.
You will most likely have to remove whatever it is that is jamming the door and replace the servo.
May 20, 2012 | 1999 Lexus RX 300
No funciona el ventilador
The flaps that control the ventilation are either cable or vacuum servo controlled. Have someone operate the controls, and try to watch if the cables or servos move properly. It is probably a broken or loose cable, or a broken vacuum line or diaphram.
Aug 28, 2010 | 1990 Pontiac Trans Sport
Traxxas tq controller has steering reversed. Left goes righ and vice versa
Towards the bottom of the controller there should be two small switches. One switch will be for the steering servo and one for the esc. Channel 1 should be for the steering servo, move that switch and that should correct your problem.
Aug 14, 2010 | Traxxas E-maxx Evx-2 Monster Truck
Center channel audio distortion and noise
I have similar problem with my Onkyo Tx-SR600. It only happens when it's in surround mode. When switch to Stereo or Direct, the scratchiness go away. Still trying to find a solution to this problem.
Apr 27, 2009 | Onkyo TX-SR606 Receiver
press and hold paper tray,zoom down,1 simultaniously you will enter in programe.F will come on display press 6 it will appear F6 press stark key change the value and then start key to exit the program press and hold these keys paper tray,zoom down stop key
Aug 27, 2007 | Panasonic FP-7735 Black and White Copier
Sony TV Trinitron
I think you have K5 model, if so, replace the all the control switches under the tube, inside the flap.There are three columns of two switches.
Nov 09, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Toys Logo
75 people viewed this question
Top Futaba Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Futaba Toy Expert? Answer questions, earn points and help others
