Question about D-Link AirPlus DI-614+ Wireless Router
Vista OS can't connect wireless to Dlink DI-614+ rounter
I have a DI-614+ rev B, and it's been working fine for a wired computer and 2 wireless computers for a long while. All the computers are running Windows XP. Yesterday, I bought a new laptop that is running Vista, and I can't make the new laptop to connect wireless to the router. But, it is ok if it's wired.Do you know if DI-614+ rev B router supports computer under Visa OS trying to connect to it wireless? THanks!
  • BoilerLand Feb 21, 2008
    I brought up the services, and wlan auto configuration was already started. I went ahead and restarted it. It didn't solve my problem.
    I could see my network there so it seemed to pick up the list of wireless networks ok. I verified the setup of the wireless network again and again, and the setup was the same as my other wireless computers. Its security type is WEP.
    Yes, the wireless switch on my new laptop is turned on. I updated the wireless adapter driver - no luck neither.
    Is there other ways that I can try?
  • mikey9000 Apr 05, 2008
    Same Problem. Vista reports that I am connection to the DLink 614 but no IP address or am able to route using a static IP address. I found a MS KB 928233, that describe Vista DHCP problems with some routers. Try the fix still does not work. My laptop is using a GW Realtek 8185 wireless. Has anyone goes Vista wireless to work with the Dlink 614 router?
Try naming the wired and wireless networks by different names (Wnetwork for wireless and Lnetwork for LAN) - vista has issues when they are the same as the wired network interface overrides the wireless one and won't allow it to connect
Posted on May 23, 2008
  • 28 Answers
Yes it does but what exactly is this it's your comp that's not connecting to your wireless here try these steps...
first click start>click in start search>in that box type in services>it gives you an option of services on the same start menu at the top click on that...
it will take you to a new screen that says services at the top on that screen you need to scroll down at the bottom and look for wlan auto configuration rt click on it and click start if start is greyed out press restart....
close services down..
click start>click connect to form the start menu> and check it gives your network name in there .if it says anything like no network found in range. pls make sure that wireless switch on your laptop is turned on...
if still you're not able to connectr it's a concern with the drivers of wireless adapter on your comp genrally on new comps its quite common get the drivers reinstalled....
Posted on Feb 20, 2008
Unable to write network settings to device error code 0x8004d112
1. this error is not recognizable.
But here is the D-link site for updating your firmware for the DI-614
this may resolve your issue.
2. You also may want to check the status of you router by logging into it and checking the "status" page (
User : admin
No password unless specified
This will tell you a lot as to what the router is doing and not doing.
Jun 18, 2010 | D-Link AirPlus DI-614+ Wireless Router
I can get on the internet if I connect directly from my cable modem to my desktop, but not if I connect through my dlink di-512 ethernet port, however the wireless works ok on my laptop with the same...
1. check the status lights on the router if they flashing you have lost connectivity.
2.unplug or press the reset button on the back of the router hold in. this will reset the router
3. reboot the PC. this will reset the PC.
4.when connected you will have to update the firmware.
I looked at the manufacturer's site and this router is discontinued but there are resources to troubleshoot this issue
go to this page above to do further troubleshooting.
Feb 20, 2010 | D-Link DI 514 Wireless Router (DI-514)
How (or whether) to configure dlink 614 as a wireless access poin
go to this link and read the manual.
You may require a firmware upgrade also.
Please rate the answer if it was helpful to u
Good Luck
Jun 23, 2009 | D-Link AirPlus DI-614+ Wireless Router
How to lock my router so neghbours cant connect
Follow the instructions on this D-Link page (it shows DI-614, but it is the same procedure for your model):
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 26, 2009 | D-Link DI 514 Wireless Router (DI-514)
Dlink DI-614 router wont stay online!
I would start with the simple things first:
1) reseast the ethernet cables
2) change the ethernet cable
3) change to different port on the router
4) uninstall/reinstall drivers
5) run spyware cleaner and anti-virus
Feb 15, 2009 | D-Link AirPlus DI-614+ Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-614+ power on problem
Have you left enough space around your DI-614 to discipate the heat? Maybe it is overheating.
Also, the problem may be with the power supply and not the DI-614 itself. D-Links tends to use the same type of power supply across many models. If you (or a friend of yours) have another DLink device, you may trying using its power supply. Before doing that, make sure that the power supply of your DI-614 and the other one have the same rating. The rating is indicated on a sticker on each power supply.
By the way, opening the cover will void your warranty, if the device is still covered.
Jan 20, 2008 | D-Link AirPlus DI-614+ Wireless Router
D-Link AirPlus DI-614+ Wireless Router Logo
883 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
