Hi have trouble with my Tivo remote wont scroll side ways,when you push side buttons scrolls up on tv seems to light up infra red on remote
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remote control troubleshooting:
When you have a remote control that does not work---some buttons either do or do not work correctly the most common cause for this is something got spilled on the front of the remote--it does not have to be a large amount.
The way all infrared remotes work is there is circuit board inside with black carbon lines etched on it--this includes lines for each funtion.
The buttons on the outside of the remote are actually one large rubber like mat and on the bottom side are coated black button like parts---when you press a button on the keyboard--the button part on the bottom of the mat touches lines on the circuit board and directs the remote to send a infrared signal to the unit it conrols.
In this situation you have two choices---
1.) Most remotes can be taken apart and cleaned for this problem--I have done hundreds of them.
a) Once you get the remote apart (the hard part) the rubber mat should lift freely off of the circuit board--if you peel it off and feel resistance---you will see whatever residue of what was spilled and got under it--gets between the board and the bottom of the mat.
b) The surface of the board where the lines are can be cleaned with denatured alcohol.
c) To clean the mat, remove it completely and with a small toothbrush and dishsoap gently rinse it and clean all the residue off the bottom. Dry it with compressed air and or a hair dryer set for cool only. When it is completely clean and DRY put it back into the face of the Remote. If there was a spill you may also find residue in the openings where the buttons on the mat protrude to the front of the remote--a good idea when it is apart to clean that and dry it also.
d) Put the remote back together and see if it now works---
Your second choice is to borrow another remote for the same kind of unit and see if it works normally---if it does and cleaning does not fix the problem--YOU WILL NEED TO buy a remote to replace the bad one.
If a known good remote does not work, it is possible the problem is in the unit and not the remote--NOT VERY LIKELY but it can happen.
SD TECH
Posted on Feb 02, 2010
  • SD Tech
    SD Tech Feb 02, 2010
    A photo for you to see what a typical remote looks like inside.
    SD TECH
Remote control code required for virgin TiVo & 50 inch blaupunkt TV combo
I have just managed to do this. I cannot tell you the code as I had to do it manually, but this is how I did it.
point the remote away from the TiVo and hold down the clear button and the to button until the free light flashed twice.
type in the code 0999 and the light will flash again. Then point the remote at the to and press and hold the channel up button. You will now scroll throw all the codes.
it will take about a minute but eventually the to will go off. When this happens release the channel up button and hold down the green on button to try turn the tv on with the TiVo remote.
if it comes on press ok and this will store the code. If it doesn't come on, use the blaupunkt to remote to turn the tv back on and then keep holding down the channel up button to scroll through more codes. When the to goes off again release the channel up button and try turn it on with the TiVo remote. If it works this time store the code by pressing ok
for me it took two attempts to turn the to on but eventually it worked on the second code
Nov 29, 2014 | Blaupunkt Car Audio & Video
Scroll channels with TiVo remote control
Use the Ch up and down button on your remote..It is opposite the volume button..you can scroll through channels quickly. Hope this helps
Aug 04, 2012 | Tivo Televison & Video
I can't get the remote to work at all. It will not even turn on the tv Is there a code you need to put in? I have changed batteries, I have pressed tv/sat and tv/video power saving, freeze I also pushed...
Lets check remote is working or not.
Watch remote front through any digital camera and press buttons on remote, if you see blinking light on remote front that means remote is sending infra red signals and if no blinking light then remote is defective and no way to fix it.
Thanks.
Feb 19, 2011 | Sony RMADU001 Remote Control
How do I set the time?
For a complete manual visit my tips and tricks page.
The time is under: Settings>Watch
To access settings push either of the right side buttons from the main default screen
Push the red button
use the right buttons again to scroll to watch
Push the red button
Right buttons again to choose time
Push red button
The Right side buttons scroll through choices, the red button is your chooser/ confirmation button. The left side bottom button will return you to a previous screen.
All other settings can be changed in the same way.
Dec 09, 2010 | Polar S150 Heart Rate Monitor
My Mitsubishi projection TV will not produce audio or video
Two things are involved to cause that problem, tv remote control and remote sensor in tv.
Upon verification of remote working, it would be confirm that remote sensor in tv is defective and need to be replaced.
Remote control sends infra red light signal to tv and we can not see that light with naked-eye, so need digital camera or cell phone camera to see it by watching remote front through camera, press any keys on remote, if you see infra red light is blinking in remote front that means remote is working and remote sensor in tv will be replaced.
If no light blinking on pressing remote buttons confirm that this remote is defective and buy new remote.
Let me know if you have additional question.
Thanks.
May 31, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Tivo DirectTV remote problem
I have a Tivo black peanut remote. Can this remote be reprogrammed to power a different receiver?
Dec 07, 2007 | Tivo DirectTV Remote Remote Control
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
