Rca colortrack 2000 26"
Hi i have a 26' tv manufact. date is 1988.....Problem first showed up as hard to turn power on.....then got worse slowly.....then the only way i can turn set on is unplugging and plugging from rear of set several times. Once set is warmed up it will turn on or off every time. when set is on it will stay on as long as you want it even for 10 hrs. It doesnt matter if you use the remote or manual button. When it doesnt work you never get the green light or click of relay.
    President:
  • 1,779 Answers
They were noted for a bad relay. I doubt if you'll find one.
Posted on Feb 18, 2008
I have a sylvania 32in replacement tv circuit board model srt2232s It doesn't turn on anymore , fuse is good , buzzing coming from a transistor I think any thoughts . Thanks
Hi there, sorry to hear. That "buzzing" you hear is most likely that power supply onboard, pulsing in a failure mode such as a current limit situation. Check for shorted rectifiers, and the common bad capacitors.
Jan 21, 2015 | Sylvania Televison & Video
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
How do I replace the fuse on a colortrack 2000, RCA
open the back , follow the power cord and you will see the fuse around where the cable enter in , remove the fuse and replace by an other of same ratings. If you don't know anything about electronics don't do that because of some capacitors holds power even if the set is unplugged .
Do that at your own risk
Aug 05, 2010 | RCA Televison & Video
I have a Brookstone large button remote, with no instruction manual. Tring to set it to a RCA colortrack 26" TV. Is there anything i can do?
Hi
Try this:
Automatic Programming
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD) until POWER INDICATOR illuminates. The remote control is in programming mode.
3. Press POWER button on remote and release . The POWER INDICATOR flashes once and stays on indicating the unit is in Power scan mode.
4. Press CHANNEL+ or CHANNEL- repeatedly until the device turns on.
5. When the device turns on, press ok to store the code.
Good luck pls rate
Dec 18, 2009 | Televison & Video
I need help finding my code for my TV. Its an RCA Colortrack
To control an RCA TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0047, 1047, 1147, 1247, 1347, 1447, 1547
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Oct 31, 2009 | One For All URC-3021 Remote Control
Lost remote were to get code for 1988 colortrack
cant get input to work to play dvd menu wont come up with universal remote
Dec 23, 2008 | RCA 27V520T 27" TV
27'' RCA appears out of focus on the vertical Edges of the Screen
I've seen this on many computer CRTs as they age past 6 years. I would imagine that the gun alignment is out. Are all the colors (RGB) fuzzy, or is it hard to tell?
1. Sometimes, extreme settings of contrast or color (usually to offset low output from aging CRT) can appear to unfocus your screen. Adjust color/contrast down if they are maxed out or close to highest setting/pot level.
2. A very likely culprit is unshielded speakers are too close to the screen. If this is the cause, the speakers' magnets distort the part of the screen closest to them (sides), and it will get better/worse as you move the speakers away/closer to the TV. If there are not magnets near the TV, and degauss function does not fix problem ('89 TVs have degauss?), see #3.
3. The focus can be set by adjusting the flyback transformer. As an experienced electrician, you should know about the dangers of messing with the insides of the unit.
If this fails, you might have other bigger issues. I'd suggest a nice trip to lead reclaimer if so. I'd say 19 years is quite a life for a CRT.
Nov 12, 2008 | RCA F27440 27" TV
RCA 52in HDTV
If this set is under a warranty period or the manufacter warranty do not attempt to touch set as they will blame you if you attaempt to open set. Call the agent who serviced it and if they refuse to take care of the problem contact the manufacturer
Mar 24, 2006 | RCA HD52W58 52" TV
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
