Question about Cuisinart BFP-10 7-Speed Blender
The lights are on, but the blender won't start
Everything is hooked up as it should be, lights go on but the blender won't start
Magic bullet
Blenders usually have some sort of interlock that prevents power from being turned on if the container is not locked in place. This could be the reason for the problem
Apr 25, 2013 | Emson Magic Bullet Express Blender
Why wont my kitchenaid foodprocessor start?
Take the bowl off, turn it on in the centre at the front where the base of the handle would normally be there is a light coloured button/plastic piece. Push it in with a matchstick. If the motor now starts then you have a problem with the safety switching mechanism in either the bowl or the lid. It is more often the lid. The only solution is to replace the faulty part. Easiest is go to a service agent and buy whichever part solves the problem.
Feb 26, 2013 | KitchenAid Kitchen Aid KFP715OB - Food...
Ginny's blender lights keep flashing
you have to have the top part on before you turn on the blender
Sep 09, 2012 | Blenders
Blender overheated
If it won't run once it has cooled down, you have probably cooked the electric motor, which is not worth trying to fix.
If you have some time to poke around, it is vaguely possible that a switch has burnt out, which can be fixed/cleaned. Another longshot is a burnt out fuse, but I doubt it has one.
Jul 22, 2012 | Oster Fusion 7-Speed Food...
My ninja blender won't start
Same thing happened to me and I ONLY used the thing 2xs (I was about to go H.A.M aka hard as a muthaF'er considering the price) then I tried the smaller cup size and it worked then went back to the larger pitcher and tried again. You have to ensure you have all the lock spots aligned and the top of the pitcher down securely. It worked after that...I also smelled like I was burning rubber at first but it works now...
Jan 05, 2012 | Blenders
I have a Waring BB185 Blender and the blender jar won't properly fit on the blender clutch. I think the clutch on the blender is somehow bent? Is the repairable? Thanks!
Hello, wendy
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 02, 2011 | Waring BB185 Work Top Blender
Breville blender won't turn on. The on light is flashing red instead of solid blue. Worked fine a few days ago.
FIXED IT - It's the screws on the bottom of the jar assembly, where the blades are attached. There are 4 Torx screws - star-shaped - and when these come loose over time the Blender will start to operate only sometimes. Eventually it will be never.
Tighten these four screws and everything will be fine!
Oct 02, 2010 | Breville BBL600XL. 5-Speed Blender
BIBC1030 Blender: I won the Wolfgang Puck Immersion Blender/Chopper ...
Replacement parts for Wolfgang Puck Immersion Blenders are available here:
http://www.wpcookware.com/categories.asp?cat=26
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
May 16, 2010 | Wolfgang Puck BIBC1030 Blender
Lights/LED lit up, but blender does not start!
The motor brushes may be in need of replacement.
Sep 09, 2017 | Cuisinart CB-600 Blender
KitchenAid 5 speed blender
Are you saying there's something wrong with the blender and it runs on high when it should be running on stir?
Aug 28, 2006 | KitchenAid KSB5 Ultra Power Work Top...
Cuisinart BFP-10 7-Speed Blender Logo
59 people viewed this question
Top Cuisinart Blenders Experts
eyecam
ray gallant
richie46
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
