Question about Whirlpool ET8CHEXSQ Dryer
GE Profile Model#DPSB513EBOWW Breaker kicked to
GE Profile Model#DPSB513EBOWW Breaker kicked to entire house, now dryer won't work. Everything else started back up.
  • 619 Answers
Have you reset the dryer breaker also. Even if doesn't look tripped turn off then back on again.
Posted on Feb 01, 2010
My GE profile model dpgt750ec dryer will not turn on - checked breaker okay, light comes on inside the door, but no power when attempting to turn on
Recheck breaker turn the breaker all the way off and then reset the breaker. Then try a different cycle. like air only or something different than you normally use and see if it works then. Motor could be out or The control switch. Make sure you are looking at a double pole 220 breaker. hope this helps.
Dec 19, 2010 | GE Profile Harmony DPGT750EC Electric...
My ge profile dryer won't start.I checked the breakers and they were ok. Any other suggestions?
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 08, 2010 | GE Profile Harmony DPGT750EC Electric...
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
I have a ge profile dryer model dpsb513eboww and the sensor dry doesn't work properly. It runs 3 minutes then shuts off. The clothes are still wet. All else works fine.
You should inside the driver and on the front or back wall will be the sensor: two metal bars that send an electric current through the clothing. When the dryer detects more current goes through, it knows the clothes are still wet and keep running. If the sensor bars are broken, disconnected, or dirty, it will read no current and think you put clothes in there that were already dry. Make sure those contacts are nice and clean. Failing that, you'll need to test the sensor circuit for voltage to see what the problem is.
Sep 19, 2009 | GE DPSB513BW Dryer
Won't start all of a sudden. Power is getting to the unit, no breakers thrown. Interior light works... just won't run. What do I check first? GE model DPSR475EWOWW
First, find your breaker box and locate the breaker that runs the dryer. Now flip the breaker off and then back on. Now try the dryer. If it made not change. Gain access to the back of dryer. There is a small panel toward the bottom that you can take off. After unplugging the dryer, take the little panel off. Look inside and check the belt. Make sure it is tight and still going around the motor shaft and pulley. With this model, there is a switch that turns the dryer off so that it will not run when the belt comes off. If the belt is on, you will have a bad thermal fuse and bad cycling thermostat. The thermal fuse is located on the top of the element housing and the cycling thermostat is located on the blower housing. When the cycling thermostat goes out the dryer then cycles on the thermal fuse until it goes bad. This then cuts the power on one leg of the 220V coming to the dryer. Remember, a dryer runs off of 220vs. This consist of two 110v legs. The element is the only component inside the dryer that works off of both 110v legs. Some component work off of one leg and the other component work off the other. When you loose one leg, some things will work and others will not. I hope this makes since. It's the best way I can explain it. If I can explain any of this or help anymore, please send a comment back to me.
Please rate solution and good luck.
Sep 07, 2009 | GE Profile DPSR475EW Dryer
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer not working.
If nothing happens, try resetting the dryer breaker pair in the house electrical panel. Push OFF, then ON.
Jul 27, 2009 | GE Profile Harmony DPGT750EC Electric...
GE frontloader electric dryer is causing an electrical surge
Check the connectors and lugs on the powercord ,wire and breaker box
Apr 07, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Getting into a ge harmony dryer seen some posts on it not heating up cannot get to element to check it model #dpgt750ec1ps
taking everything out though the front my breaker was bad not getting both legs of my 220 after I put it all back together I trip the high temp thermister and had to take it all back apart to reset it so do not run your element without air over it for to long.
Nov 29, 2008 | GE Profile Harmony DPGT750EC Electric...
Dpsb513eboww elictric dryer
ck thermal fuse on heating element usually the smallest of the thermostat looking parts on the element housing
May 28, 2008 | GE Dryers
Whirlpool ET8CHEXSQ Dryer Logo
219 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
