I have a GE front loader, about 4 years old, it seems to be stuck and won't even if unpluged and let sit awhile resume normal operations when plugged back in. It indicate no specific cycle, sounds likes it attempting to evacuate water, and never leaves this mode.
  • 39 Answers
Sounds like it is trying to drain water. Pump filter is probably clogged. Washer wont work properly if it thinks water not draining all the way. Pump assemblies usually are at bottom behind lower front panel. Remove pump cap and filter, clean and reinstall. Should solve problem.
Posted on Feb 03, 2010
Why will machine NOT turn off or START even when unplugged?
try plugging it back in and give it a moment for it to unlock and check its self some front loaders normally have a self diagnostic system to check if it has a problem and it may unlock its self after pressing the power on key
May 26, 2014 | Maytag Washing Machines
Front loader won't start on certain cycles
Hello sidneyskiss - From what you have described if only the normal cycle is working, then there seems to be a communication problem coming from the main control board or wiring failure. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart washer. If it proves to be ineffective, I would suggest contacting a professional technician to move forward accurately.
Jan 08, 2013 | Frigidaire GLTF2940ES Front Load Washer
My GE fridge model PFS22SBSASS clicks for hours at a time then goes off for a day or so. We suspect thermostat. It is 4 years old. Seems to be working normally but fear breakdown
Greetings,
you say you hear a clicking sound? if this happens every five minutes or so and the compressor won't start...its most likely the ptc assembly(starts compressor) its even possible compressor at fault, but if it works ok for awhile most likely the PTC needs replacing....Bruce Denton
Nov 28, 2010 | GE Refrigerators
Scorpius K3NT USB Keyboard prevents resume after standby in Win2K
When entering standby, the usb ports go to sleep. Most motherboards allow you to tell the bios that you are using a usb keyboard. That should solve the problem. I keep an old ps2 keyboard plugged in and on the floor as a 'just in case'.
Jul 24, 2009 | Mini iOne / Qtronix Scorpius K3NT PS/2...
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I am considering purchasing a front load GE washing machine. I am curious if the inner drum and the outer drum are both metal? I am comparing the advantages of the GE front load with the Miele and the...
I can't speak for all, but my GE front loader has a stainless inner and a plastic outer tub. I don't know what the benefit of a all metal would be. The plastic outer tub seems to hold up fine, The only problems I have expereinced with the washer tubs were the bearing going bad after the seal failed, but its 10 years old. I consider that normal wear.
Jan 08, 2009 | Washing Machines
Old whirlpool mini dryer
Those are front tub supports that keep the tub from scraping.Unless you start hearing a rubbing or scraping sound your dryer is ok.Just keep a ear open for awhile for any scraping sound.If you need help in the future with anything ,Im more than happy to help you.
May 24, 2008 | Dryers
Have GE GJSR2130 or
is this machine top loader or front loader
Mar 15, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
