Question about Whirlpool ET8CHEXSQ Dryer
Model GEW9200LWO control lock light
Model GEW9200LWO Wife 2nd load in tonight and it wont come on only the control locked light is on
  • Whirlpool Master
  • 19,396 Answers
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool.
The front light lit on my Whirlpool dryer...
Regards..
Posted on Feb 22, 2010
  • 619 Answers
Even tho the door lock light is working the switch has dropped a leg supplying power to the rest of the machine. Repace the door switch and you should be good to go. Even tho you have a GE it was made by frigidaire for GE. Common problem with the newer switches. They have gone back to the originals as the replacement for this.
Posted on Feb 01, 2010
Maytag front load washer model #MAH4000AWW. Just happened! Water fills then nothing. Wife says it "seems" like it wants to do something but doesn't
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
Car wont start but lights and radio still work.
this happened to my wife tonight with her 89' maxima but the alarm went off while she had the car in gear and opened the passenger side door to shut it all the way she got the alarm off but the car would not crank..... lights, radio, everything was working just would not turn over I took the keys out locked the driverside door and put in the key and it resets the alarm and car started right up:)
hope this helps,
scott
Sep 29, 2010 | 1989 Nissan Maxima
Duet GHW9150P Front Load Washer: control locked light stays on ,wont let you do any...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet 2004 front load washers door is locked, time is flashing and pump is on. Unable to stop or open door. tried to unplug. Control lock is not on. My wife tried to add clothes when the add a...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
MY CONTROLS ARE LOCKED
Press and hold the End of Cycle button for 3 seconds.
Jun 05, 2008 | Whirlpool GEW9200L Electric Dryer
Kenmore HE4t Washer stuck in "controls locked" mode
you need a new cpu you can unlock door by removing bottom panel reaching up to the door lock and pulling a little ring on the bottom will manualy unlock the door
Nov 08, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Flashing Control lock light
Press 'options' & 'select' for 5 to 6 seconds, controls may unlock (depending on your model) If it is a key you see, it is the child lock.
Apr 29, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool ET8CHEXSQ Dryer Logo
244 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
