Invalid disk error
Hi, I am having an invalid disk error on my son's portable Digital Labs dvd player.
  • rgannotta Oct 12, 2008
    My son's player won't play a dvd. It gives and error message, then says "no disk".
  • crimsonx Jan 21, 2009
    my COBY DVD player stops playing my movies after atleast 30 min with the invalid disk error. some it wont even play again, but some it will but stutters and skip for the rest of the movie
Pio124- try cleaning the laser with a dry Q-tip,there may be dust on the laser.If this don't help you have a more technical problem. cooltekFeb.18/08
Posted on Feb 18, 2008
Toshiba Portable DVD will not spin upon start up
If the disc does not spin it will cause the optical reader to not read the disc, which will give you the "no disc" or "invalid disc" error. If a disc will not spin, the most common cause of this is due to a spindle motor malfunction. The good news is that it can be fixed on average of between $70-90 dollars depending on what service repair technicians charge in your local area. You can fix the problem yourself if you have the patience and a bit of knowledge, but I can tell you from first hand experience it is a pain to do this.
The pictures below provide you an idea of what you are looking at.
I hope this helps give you an idea of what the problem is and helps you solve the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you.
Feb 06, 2010 | Toshiba SD-P1900 Portable DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Dan
Feb 18, 2009 | Televison & Video
Wharfedale DVD- 265 saying invalid disc
Check and see if there is dust or dirt or something on the lens. Dirt, grease and fingerprints will cause a DVD player to have read errors.
If it a new player, or under warranty, get it replaced. It sounds like it is failing.
Hope that helped.
Jan 01, 2009 | Wharfedale Televison & Video
My coby portable dvd player keeps telling me that I have invalid
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Thanks for using FixYa.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call the number above for instructions on getting the unit exchanged.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 01, 2008 | Coby TFDVD5000 Portable DVD Player
Invalid Disk
Sounds like a damaged disk or a dirty laser lens.
Clean the disk, and have the optical drive professionally cleaned. Your laser could also be burning out as well. :(
Hope this helped out.
-Pro Hack
Oct 30, 2008 | TruTech PVS12701 Portable DVD Player
Venturer portable dvd player
it is dirty needs a good cleaning or the laser needs to be replaced
Jun 20, 2008 | Venturer PVS177W Portable DVD Player
Kawasaki DVD"Invalid Disc"
My DVD player wouldn't play Any Disk. What Can I Do?
Nov 30, 2007 | kawasaki PVS32801 Portable DVD Player
"invalid key" error
your set needs a tech take it to be repair you cannot do it yourself if you do not have a knowledge of electronics repair.good luck
Mar 17, 2007 | Cyberhome CH-LDV1010A Portable DVD Player
Televison & Video Logo
670 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
