I have a Kenmore 11073954101 elite dryer that has no heat but drum tumbles...how do you test for problem?
    Genius:
  • 1,122 Answers
If you have a meter you can remove the bottom plate and get access to the fuses-mike
Posted on Feb 01, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
My Kenmore Elite 110.62932100 won't tumble or heat up.
try the homes 240volt circuit breaker it may not show its tripped but one of the 2 phases can trip out, (just reset the breaker) and if this happens either the dryer drum motor will turn or the timer will run, but not both as these 2 components each use 1 of the 2 phases 120 volts to run,but the heating element needs both 120volt phases for 240volts for the heating element to heat,this is what your issue sounds like to me,hope this helps
Dec 09, 2012 | Dryers
My Kenmore Elite Gas Dryer in Refresh mode the cloth comes out wet.
I think the refresh mode is a no heat tumble only setting... just to fluff your clothing...
if they were wet they will not dry on that setting...
heatman101
Aug 27, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
My Kenmore Elite dryer will not heat. It tumbles
REPLACE THE ELEMENTS, YOU CAN CHEC THEM WITH AN O METER TO SEE IF THEIR NORMALLY CLOSED AND NOT OPEN, BUT I WOULD THINK THIS IS THE PROBLEM IT USUALLY IS
Jul 10, 2010 | Kenmore Dryers
Dryer is tumbling but not heating
if you remove the back you will see the heater box to your right,at the top of the box is the heater fuse,also the bottom half of the box is the heater coil,it come off just remove the 2 screws,if you have a meter you can test it if not take it off and look to see if you see a broken wire anywhere,your model number is inside the door-mike
Jan 28, 2010 | Kenmore 63942 Dryer
Kenmore dryer 75731 won't tumble. It heats fine.
Hi.
The machhine is belt driven check the belt first.
If the motor is must be tested energizing it.
In all cases test the lid switch to ensure it is not opening contact when machine starts tumbling.
The wiring harness to motor must be tested.
If there is no other fault elsewhere, replace the timer board.
Start from the belt, if the machine is heating, then it is probably a broken belt.
Nov 13, 2009 | Kenmore 63942 Dryer
Kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Oct 08, 2009 | Kenmore Dryers
Tumbles but no heat
Probably your heating element.
May 26, 2009 | Dryers
Kenmore Elite gas ddryer model 72062--No heat
Check the glow coil ,if its not glowing run a test for voltage when its heating ,should be around 117 volts.check thermal fuse.
Please Rate This !!!!
Aug 10, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Model 110.85087-400
Do you have a volt-ohm meter to check the heating element and thermal fuse??? I take it the dryer comes on and tumbles but doesnt heat up???
Jan 19, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
