I have a Yamaha RX-V657. the problem is i get nothing from front speakers. checked wiring by switching speaker leads to differnt channel and speakers work ok. tried running auto set up and does not recognize that speakers are connected. did i blow a fuse inside or something?
  • rwicinski Feb 01, 2010
    thanks,it was the speaker switch not on A. could have sworn i checked that and every thing else i could yhink of. oh well . thanks again, Rob
    President:
  • 1,114 Answers
First, check the A/B speaker select switch on the front of the receiver and make sure A is on. It will light up on the display. If that is on and you still have no audio, make sure "Direct" is off. If it is off then connect a cd or dvd to the direct input on the jack panel in the rear and turn "direct" on. If you now have audio, your receiver has a bad chipset and needs repair. If it's still under warranty have it repaired, if not. Think long and hard over a replacement model. It's a 400 to 500 dollar repair. Hope that's not the case! Hope this helps
Posted on Feb 01, 2010
My Yamaha RX-V563 receiver displays "Check Speaker
Look closely at the rear connector panel of the receiver and look for pieces of stray strand wire that may be touching the speaker A binding post and the receiver chassis. If you are not using strand wire connection to the binding post then check whatever connector type you are using such as banana plug or spade plug for breakage or corrosion, the same goes for the speaker cable itself which isn't always so easy to detect. A few broken strands can cause a problem.
If it is clean, turn off the receiver and disconnect the speaker cable. Check the binding post for tightness; if you can wiggle it then it is broken and needs to be replaced.
Oct 03, 2011 | Yamaha RX-V563 Receiver
The receiver shuts down when zone 2 is turned on
Disconnect the speakers on Zone 2 and try to turn on the receiver again. If the receiver works, there is a shorted speaker wire, pinched wire, or a blown speaker on zone 2. Good Luck
Jul 01, 2007 | Yamaha RX-V657 Receiver
My problem is conect bose 901v to reciver yahama rx-v657
If you cruise around fixya solutions you will find a number of MY postings for many different receivers.
The difficulty you face is that the RX-V657 lacks the necessary Pre-Outs to feed the Bose 901 Active Equalizer which would feed the necessary dedicated amplifier you will need to route Front Channel programming to the 901's and ONLY the 901's without affecting anything else that flows through the RX.
I have 901's in my multichannel rig alongside 301's and a subwoofer. I know what I'm talking about.
Aug 25, 2011 | Bose 901 VI Main / Stereo Speaker
Yamaha RX-V465 switches off when increasing volume beyond -21.0dB
What speakers you have connected? This receiver supports only 6 and 8 ohm speakers (not 4 ohm). Also check if the ohm settings are correctly set in Advanced Setup (in standby press on the front panel STANDBY while holding STRAIGHT button). In this menu check the setting SP IMP. (speaker impedance) if it maches your speakers (6 or 8 ohm).
Disconnect all inputs and also all speakers. With nothing connected, try to increase the volume. If it still will power off, the unit is probably faulty and should be repaired.
If it does turn off only with speakers connected, check the speaker wires and the speakers, the problem will be there.
Mar 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
It turns off with an error to Check Speaker wires. It's done this in the past, usual if I push the volume too it's threshold. It would always bounce back. Now it shuts down at just about it's mid-peak...
Did the fact that it was responding negatively to the loud volume not suggest it might be a bad idea to keep doing it?
The threshold on the volume knob is NOT where normal undistorted listening levels are found. Given a normal level of input you could be pushing your amp so hard that it clips or distorts and kills your speakers.
Do what it asks: check the speaker wires for shorts. Or disconnect the speakers and pray it comes back to life, then isolate the shorted (dead) speaker.
Feb 23, 2010 | Yamaha RX-V657 Receiver
I would like to know how to connect my Bose 901 to my Yamaha RX-V765 AV Receiver.
Ahhh, the good ole Bose 901. (I like those)... And you want to connect them to the Yamaha RX-V765 AV receiver. That should be a piece of cake. I assume you only have two Bose 901 cabinets. If so, you simply need to connect one end of your speaker wires to the terminals found on the 901 cabinets, and the other end of the speaker wires need to go to the Front Left and Front Right speaker outputs of the RX-V765. The RX-V765 is a 7 channel surround receiver. Weather you run it as a 7 channel theatre or as a more classic 2 speaker configuration, you will want to run the 901 cabs from the Front L and Front R speaker outputs, unless for some reason you want to specifically use them for any of the surround channels in which case it will not harm anything if you use them for surrounds - it's just that if you're simply wanting to use them as your principal speakers, you want Front L and Front R.
So connect them as I explained, power the receiver up, put on your favorite CD and enjoy!
Oct 24, 2009 | Audio Players & Recorders
RX-V1600 when i turn on no sound or channels display on
If you are sure that the speaker wiring is correct and connections are good, then:
  • Check the input and output connections are correct for each source.
  • Check that the input mode is not set to DTS or Analog - rotate the input selector to the source and the press the input mode, set it to Auto.
  • Also check that the front speakers to be used are selected A or B (or A+B).
  • If there is an optimiser microphone supplied with this receiver, ensure that it is not still plugged in.
Hope one of these solutions work for you.
Jul 19, 2009 | Yamaha RX-V1800
Yamaha RX Z9 and two-channel system integration
The A-B speaker switch is intended to direct amplifier output to a pair of speakers in a different location when set to B.
Feb 26, 2017 | Televison & Video
RX-V995 Left Speakers Channel
a b switch? is pretty common. other speakers work?
Feb 16, 2008 | Yamaha RX-V995 Receiver
Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Oct 13, 2007 | Yamaha RX-V657 Receiver
27 people viewed this question
 Grubhead
Grubhead
