Question about GE Dishwashers
Where is the fuse on my ge dishwasher located
Where are the fuses in the nautilus dishwasher
I do not believe there are fuses inside the dishwasher.
When the Use and Care Manual mentions a fuse (Fuse is blown, or the circuit breaker tripped), it is referring to the Fuse Panel/Circuit Breaker Panel.
What problem are you experiencing?
Dec 31, 2014 | GE Nautilus 24" Built-in Dishwasher
For a ge dishwasher mod#ghda485nools:on startup mode lights blink and pump turns for 10 seconds then shuts off
00023396.gif small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
transparent1.gif Find a part for your Dishwasher godark_3.gif How Dishwashers work godark_3.gif What is wrong with your Dishwasher? godark_3.gif Email the RepairGuru for help with your specific problem godark_3.gif Maintenance tips for your Dishwasher godark_3.gif Answers to common questions about Dishwashers (FAQ) godark_3.gif Locate your Dishwasher model number godark_3.gif Accessories for Dishwashers godark_3.gif Appliance Recall Information godark_3.gif RepairClinic.com is the web's best resource to buy parts for your Dishwasher and get free Dishwasher repair advice for all major brands of Dishwashers including Admiral, Amana, Asko, Bosch, Caloric, Crosley, Electrolux, Estate, Frigidaire, GE, Gibson, Glenwood, Hotpoint, Insinkerator, JC Penney, Jenn Air, Kelvinator, Kenmore, Kitchen Aid, Magic Chef, Maytag, Modern Maid, RCA, Roper, Tappan, Thermador, Westinghouse, Whirlpool, White-Westinghouse, and more.
Jul 04, 2008 | GE Dishwashers
I have a GE Quiet Power 3 that has completly died. I cannot get a light to come on or anything to beep when pressing buttons. I checked the circuit breaker and outlet and they are both working fine. I...
A dead set simply means a cut off of power supply. Open the back cover of your dishwasher . Locate the area where the AC cord is located and look for the plastic fuse holder which is usually installed in one of the AC cord line open it and replace the fuse inside with the same amperage or value.
Nov 22, 2010 | Dishwashers
Fuse for dishwasher
I am not aware of any fuses located in the dishwasher. If your dishwasher is has no power coming to it check your house breaker.
Jun 07, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Water level is not high enough when dishwasher starts up on a GE dishwasher.
Try tapping on the flood float valve located on the bottom of the tub.. usually located on the front left. It looks like a small upside down plastic glass. Be gentle don't beat on it. Also check for kinks in the supply line if you can get to them. Restart and check. Repeat if necessary.
Thank You,
RSMITH972278
Oct 13, 2009 | GE 24 in. Profile PDW7800 Built-in...
DISHWASHER WILL NOT POWER ON AND THERE IS POWER TO THE OUTLET
more than likely the door catch switch or the on off button, check these 2 first
Oct 13, 2007 | GE 24 in. PDW9880LSS Stainless Steel...
Blew the Fuse in my GE PDW9880LSS Dishwasher
There is no in-line fuse in your dishwasher. If water has gotten into the junction box, (where the dishwasher and supply line are connected) it could have shorted at that point. Call a technician for service.
Sep 27, 2007 | GE 24 in. PDW9880LSS Stainless Steel...
Dishwashers Logo
598 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
