I have a GE washer (WBB4500G2WW) - about 18 months old. It won't agitate or spin. It fills and drains fine. I've bypassed the lid switch and also bypassed the fusable link by wiring in a temporary connection in both cases. Still no agitate or spin. Any suggestions?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    GE does NOT use a motor coupling!
  • 714 Answers
Have you checked the motor coupling?
Posted on Feb 01, 2010
I have a GE washer (WBB4500G2WW) - wont aggitate or spin
The BELT... Part number wh01x10302
30% of the time is the issue here:
http://www.appliancepartspros.com/ge-belt-wh01x10302-ap3968432.html
Have a look at appliance-parts-pros (video guide)
http://www.appliancepartspros.com/repair-help/general-electric-washer-wbb4500g2ww-repair/wbb4500g2ww-pumps-but-will-not-spin.html
May require a specialty tool to mount the belt
(depicted in VIDEO... Sold on site): view here:
http://www.appliancepartspros.com/ge-service-kit-belt-wx05x20641-ap5957260.html
((not entirely convinced the tool is critical but the
Also check prices on eBay (top seller, free shipping
WH01X10302 AP3968432 1264395 PS1482278 WH01X10353 Washer Drive Belt eBay
Hope this holds off trashing your three year old washer...
Carnac the Magnificent
Jan 15, 2018 | Whirlpool Washing Machines
Washer will fill and drain but not agitate
Check the lid switch if it is a top loader.
Nov 04, 2009 | GE Washing Machines
My washer doesn't agitate or spin, it just drains and fills up
That sounds like your lid switch. The lid switch on most models of top load washers will be bypassed on fill and drain. As a safety the lid must be closed for agitate and spin.
The lids switch is a pretty easy part to replace and is inexpensive.
Oct 02, 2009 | GE Washing Machines
GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
Fills and drains but will not agitate or spin.
Try bypassing the lid swith, If this solves your problem make sure you replace the lid switch, they are there for a reason.
Jun 22, 2009 | GE Washing Machines
GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
202 people viewed this question
Top Washing Machines Experts
