Question about Apple 12" iBook G3 700Mhz with 256 RAM, 20GB CD Drive (p/n IBG3-700-CD)-Linited Supply PC Notebook
My ibook g3 running slow
Note: When I boot up in safe mode, this problem doesn't happen. Only, safe mode's no good because I can't connect to the internet.
When I turn on and log into my g3, everything works just fine and goes lightning-fast--finder, word, safari, etc. But only for about ten minutes at the most. It slows down and slows down and slowwwws down until all I get is the rainbow pinwheel thingy, and I have to shut my g3 down by force.
I know the thing is old, but it worked perfectly until a month ago, and it still goes really fast and does everything I need...until I get this problem after ten or so minutes.
Help me, please!
  • 96 Answers
If you have the original Install CDs that came with the iBook put in Install Disk 1.
When the Menu Bar appears go to Disk Utility (under file manu). Choose your HD and look for the S.M.A.R.T. status. It should be Verified. Then choose Repair Permissions. After that is done choose Repair Disk.
If none of this works find the Hardware Test Disk and run that.
Posted on Feb 01, 2010
My ibook g3 gives me this when i boot it up(just got it from eBay) and the cd drive doesn't open up
Probably last owner had experiment with installing windows on iBook something that apple does not support until now. You can solve this by buying a genuine copy of macintosh (should not be more than 10-20 bucks on ebay for this is a kinda old version not sure which one though) and reinstall it basically from the begining.
Apr 12, 2013 | Computers & Internet
When booting desktop doesn't load
There are a couple of quick fixes you can do.
First, boot into Safe Mode (Repeatedly tap the F8 key while the system is booting, before the windows logo appears) A Menu will pop up, press Boot Into Safe Mode. From there you can try a System Restore to a known good date.
System Restore - Click Start -> Control Panel -> On the top right, type "System Restore" without the quotes. Click on "Restore system files and settings from a restore point". You can choose the recommended restore or a specific date.
The other option is to boot into "Last Known Good Configuration". To do this, use the F8 trick again while booting, but instead of Safe Mode choose "Last Known Good Configuration".
Please note that either of these run a risk of some data being lost from the time the restore point was made. You "shouldn't" lose anything but just want to make you aware.
If this helps please give a good rating. Thanks.
Jun 30, 2011 | Gateway Computers & Internet
I want to install linux on an old ibook cd drive wont let me boot from it . I have a powerbook that i can hook up to the ibook thru firewire. the ibook harddrive has been wiped clean. what would be the...
I would recommend booting from USB. Go to pendrivelinux.com and pick a distro. The utility is awesome and makes it easy to boot from usb. make sure that bootusb is an option in BIOS.
Good luck
Joe
Jan 08, 2011 | Apple iBook G3 Mac Notebook
My ibbok 3g wont play dvds or youtube? help
Many iBook G3s came with optical drives for CDs only, not DVDs; and the decoding software for many of today's popular video formats runs extremely slow on all G3 processors. It's not clear that there is anything wrong with your computer other than its age. The first iBook G3 models were ten years old last February.
Jul 10, 2010 | Apple iBook G3 Mac Notebook
I have a ibook g3 clamshell laptop. I am trying
The G3 iMac clamshell speaks 802.11b wireless signal only. If your router is an 802.11n router, this symptom is known to occur, especially if you have any level of encryption (WEP, WPA, WPA2) on your router signal. Try temporarily turning the encryption off on your router and disabling N mode (set to G mode only) and see if this solves your problem. If so, obviously you don't want to leave your router unencrypted, but you may have to leave it set to G mode as long as you want your clamshell to be able to access it.
Nov 17, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
I forgot my administrator password for my mac g3
If you are running OS X put the appropriate system disk in the disk drive. Boot up using the c key. Once booted go up to the file menu and go to the reset password menu and reset your password.
Oct 04, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Wireless router problems
I'm sorry that you have an ibook g3 but it's good that you are new to mac, there is still time to change.
However, neither of these are the cause of your problem.
You'll need to give your computer the correct password for the "router" that you are trying to access.
Jun 06, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Grey screen on G3 ibook
Hi, Sorry you are having trouble,
Sounds to me like you're going to have to re-open that puppy and check all the connections, sometimes, when putting it back together, some cables are stretched and come un plugged...
Be careful, go slow...
Mar 29, 2009 | Apple iBook G3 Mac Notebook
G3 ibook clamshell startup
The clamshell is 9 years out. The life of a hard drive under normal use is 4. Time to get a new machine? Does the clamshell have a firewire port?
May 04, 2008 | Apple iBook G3 Mac Notebook
IBook G3 900mhz 14" lcd power failure
One more thing to try is a little know power management kuda switch on some macs. On some Ibooks if the keyboard lifts off look for a little red or green button. If you can find it remove the battery and all power let sit for 20 minutes then press that button for about 15 seconds. That puts the power management processor back to factory settings. If it doesn't have the kuda switch remove all power like before and hold down the start button for the same time. My guess is it isn't the main cpu or it wouldn't boot, it will shut down if it gets to hot though. Make sure your fan is working to eliminate it being that.
Apr 21, 2008 | Apple iBook G3 Mac Notebook
Computers & Internet Logo
156 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
