Question about Compaq Computers & Internet
Want put additional hard drive in presario s6020wm is this possiable, also do the rpm speeds have to be the same I have a maxtor diamondmax plus 9 80g that spins at 7200, the one in the computer spins at 5400 can i use the maxtor. Also there is data on the maxtor, will this interfere with my system.
    President:
  • 2,351 Answers
It’s very possible to do and no it doesn't matter that each drive runs at different Rpm speeds.
The difference between a hard disk drive that runs at 5400Rpm and a 7200 Rpm is data transfer speed. The 7200 drive will run faster but the drives cache also plays a big part when transferring data. A drive that runs at 7200Rpm with a 16MB cache will run faster than a drive with 8MB cache. The 7200Rpm drive will run a little hotter than a 5400Rpm drive and use a little less power. Typically you’d want to use the 7200Rpm drive as the primary drive. (With windows installed on it).
The 5400Rpm drive should be used as a storage drive and be connected on the same data cable as a slave drive. How to safely remove data from the 5400 drive. Before you shut down the system, open windows explorer. Click on the C:\ than delete the Boot.ini, AUTOEXEC.BAT, and IO.SYS files. (By doing this the drive will no longer be bootable but all the data will stay intact). Shut down the system. Remove the 5400Rpm drive from the system. Install the 7200Rpm drive. (The new drive is an IDE drive. Set its jumper so it is a Master.) Guide to setting-up an IDE drive; http://freepctech.com/pc/001/installing_ide_devices.shtml
Set the jumper for the 7200 drive as a Master with a slave. (The 5400 drive will be added later).
Once the drive is configured and installed boot the system and enter the bios/CMOS menu. Press the delete key to enter the bios or watch you're screen you may need to press the F1, F2 key or F10 key to enter the bios menu. Instruction on how to move about while in the bios is shown at the bottom of the bios screen. You should see the model numbers of you’re 7200 DiamondMax drive within the main bios menu.
You will also need to set the boot menu / boot order.
Open the Boot menu. A typical boot menu would list as follows:
1st Boot device, Floppy disk drive
2nd Boot device, CD-ROM drive
3rd Boot device, Primary hard disk drive.
4th Boot device, not needed
Compaq does not provide bios settings within their user guide. Before you save and exit the bios, open the CD-ROM drive and load you're windows CD or the restore CD from Compaq. Save and exit the bios. When the system reboots it should start up the windows CD or the restore CD. Follow the on-screen instructions from the restore CD. Once windows is installed update windows. When finished it is now time to add the old 5400Rpm drive. Shut down the system. You will need to change the jumper on the on the 5400Rpm drive. Set the jumper to Slave and insert it into an open bay. Connect the data cable and power cable. Check that all cables are fully connected. Boot you're system. Windows should load. You're 5400Rpm drive will most likely be labeled as letter E. You can change the drive letter order by opening the run window. Click Start and in the run window type in: diskmgmt.msc than click ok. Open Help. Click, help topics. Click on disk management.
Compaq Presario S6020WM Desktop computer web site;
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00058482
User Guide for S6020WM
http://h10032.www1.hp.com/ctg/Manual/bpb13287.pdf
Cheers'
Mike
Posted on Feb 01, 2010
Maxtor diamondmax plus 9 hard drive not seen by computer
I'd say you did a good job troubleshooting. Replace the drive.
Dec 29, 2012 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
What is the jumper pin placement to make a slave of a DiamondMax Plus 9, 80GB hard drive?
The manual is linked below and section 3.3.1 covers jumper settings.
The slave setting shows the park position so you have a jumper on the drive so you can reconfigure it later.
A quick answer is that the slave setting is no jumper at all on the jumper pins.
DiamondMax Plus 9 Manual - DiamondMaxPlus 9.book
Feb 12, 2011 | Maxtor Hard Drive
What is the jumper setting to service (format) the diamondmax plus 9 disk?
This document might help you:
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/diamondmax_plus_9_manual.pdf
Oct 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Windows Xp Setup Problem : "setup cannot access the disk". I have HDD: Maxtor Diamondmax Plus 9 80GB ATA/133 HDD.
try doing a F disk on the hard drive first then format it and make it the active drive and then try installing the xp software. if it has had another operating system say for instance windows ME it will not install on that drive without removing it. You can also go to www.maxtor.com and download their free hard drive tools to see if there is a problem that thier software can fix. the software is for free.
Jan 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
What are the jumper setting for slave on maxtor diamondmax plus 9
This web page shows the jumper settings you require.
http://www.google.com/imgres?imgurl=http://www.seagate.com/staticfiles/images/support/en/us/mxo_ata_jumpers_rev.jpg&imgrefurl=http://forums.macrumors.com/showthread.php%3Ft%3D387061&usg=__oBf6Czrk9E5_4ovUuuyxJCl68fY=&h=411&w=850&sz=83&hl=en&start=3&itbs=1&tbnid=J_I6lp0cCbuIwM:&tbnh=70&tbnw=145&prev=/images%3Fq%3DJumper%2Bsettings%2Bold%2BMaxtor%26hl%3Den%26sa%3DG
Dec 01, 2009 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
Maxtor DiamondMax Plus 45 7200 RPM 30.7 GB HDD suddenly makes clicking sound when started and will not be recognized by Win XP OS. The drive had been working flawlessly. Any suggestions?
Clicking sounds is an indication that the platters have a bad device internally. Once that happens the hard drive is no good, run the serial# on Maxtors website to see if its still under warranty, gd lk
E
Aug 01, 2009 | Maxtor DiamondMax Plus 45 (53073H4) 30.7...
Windows xp shows hard drive as 30g. I have diamond max plus 9 120gb model 6y120PO s/n y25W76E bios shows maxtor 6y120PO capacity 33821mb
It is probably partitioned. Right click on "my computer" select "Manage" and then look at the disk manager. You will find that the rest of the drive is there, but un partitioned and un formatted.
Jul 11, 2009 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
When i start my computer my drive (maxtor diamondmax plus 9) freezes and starts makeing a knocking voice...? do i have to get a new 1? or this can be fixed
it sounds like hardrive as dropped a disk you could try a prog called hardrive regenerator of the net if i was you i would get a new hardrive i have trouble with maxtor drives , seagate or western digital seem better drives to use
May 17, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Computers & Internet Logo
427 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
