Need help with washing machine
Ok well the knob on the washing machine wont turn the arrow. the arrow being the piece that turns the washer to its setting. well i took the plateing off and unscrewed it to try and take it off. i cant figure out how to take the knob of from settings. so what i wanted to know is how to take the knob off. and is there like a store or a place i can go to replace the the knob.
  • 714 Answers
You can get a knob from REPAIRCLINIC.com just type in your model #
Posted on Feb 01, 2010
Testimonial: "was hoping to find some like a store"
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
My washer seems to be stuck on a boil wash i turn the knob to another setting and the time light flashers but will not stay on and the washer start a boil wash
Possibly the water level sensor inside is out of order. So, the program only gives the command for filling with water and heating.
Sep 10, 2017 | Hoover Nextra HNT 2135 Top Load Washer
Program selector knob continues to turn
COULD BE THE SPLINES ON THE SPINDLE PULL KNOB OF AND SEE IF CRACKED OR THE SPLINDES WORN ON INSIDE OF KNOB .IF OK THE SELECTOR NEEDS REPLACING.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Indesit W 123 Front Load Washer
The knob is not working. It just turns without starting the washer. I have to press down hard to get the knob to turn to the cycle I want. Is there a way to fix this? GE Top Loader WHDSR109J
This is a common failure. The teeth on the knob have worn off. If you pull the knob out you will see a small clip that can be pulled off this will release the knob. Usually both pieces of the knob need to be replaced. For diagrams and illustrations enter your model # at www.appliancehelponline.com
Jul 22, 2010 | GE WVSR1060A Top Load Washer
Machine wont fill with water.i have checked pipes and they are okay.if you turn program knob to the spin cycle it will try to enpty.also you can still open the door
Hi there....looking at the programe selector knob....you should see at three positions on the panel a black dot.....ok.......(1) close the door of the machine and switch on the power....(2) turn the programe knob to any one of the dot positions....(2) push the start button....a red indicator lamp should flash 3times and then remain steady indicating the program has been cancelled....(3) Now select a new wash program and push the start button....machine should operate ok....If not check the drain pump to ensure it is not blocked...or wiring loose ...or burned out....if this is ok...then your most likley looking at a module failure...
regards Sir Galahad
Sep 03, 2009 | Indesit W 123 Front Load Washer
The cycle knob is loose
Should still be under warranty .  Call for service.  There should be no charge.
May 29, 2009 | GE WBSR3140DW Top Load Washer
Changing the spin dial
I was just trying the same thing. I have a kenmore 80 series that wont even start to fill. i thought maybe the dial component was broke so i wanted to take it out. it was held on by a screw. I am not sure if there is a certain position the knob must be in, but mine turned counterclockwise. i have a feel for things like this so i might have done something else out of instict. but it is held on by a screw.
Apr 25, 2009 | Kenmore 24032\24036 Top Load Washer
GE washer selection knob doesn't engage
The knob it probably stripped. i would replace.
Mar 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 model 110
If you are talking about the Cycle Selection knob, turn the washer to an OFF position, or unplug. I can't remember if you need to pull the knob out or leave pushed in, but the knob will come off by turning it counter-clockwise. After unscrewing it and removing, the plastic dial under the center knob will simply pull off. I hope this helps you. If you need further assistance, please let me know.
Jan 15, 2009 | Kenmore 24032\24036 Top Load Washer
Ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Dec 01, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
