Question about Acer V223Wab Widescreen Lcd Monitor Blk
My acer v223w monitor popped p "you are not in prefereed mode so i clicked on preered mode and it wnt blank pleae help
  • 2,229 Answers
The preferred mode is the resolution at which the display looks best. Unfortunately, you switched to a higher resolution than your monitor can handle.
Now you must start in safe mode and change the resolution.
If you can't do that, hit the F8 key as the computer starts and if you see the option to start in VGA mode, choose that. You can then set your display back to a lower resolution.
Posted on Feb 01, 2010
Acer V223W off center
it happened to me. I changed computers but that did not solve the problem so it's not the video card. what did help was I turned off the monitor to reboot it then, using a different computer I reset the resolution to the lowest possible setting. when the monitor adjusted to the new resolution it reset itself. I then set it back to the higher resolution and everything was centered again.
Mar 12, 2013 | Acer V223W 22 inch Monitor
Can i hook up my xbox to a Acer V223W EJbd monitor
Yes, you can get a DVI or AVG connector and use those.
Mar 09, 2013 | Acer 22" V223W EJbd Widescreen LCD...
Acer v223w on and off
You could have a faulty power supply. If the capacitors have a blown (deformed top) then they are faulty. Replacing these capacitors with new ones may fix the problem provided nothing else is faulty. Make sure you replace them with the same voltage and capacitor rating.
Nov 30, 2012 | Acer V223W LCD Monitor
Acer V223W monitor At 1680X1050 resolution cannot get full screen. Windows Xp
Just press the AUTO button for two seconds to activate the auto adjustment function.
Mar 21, 2011 | Acer V223W
Desktop is larger then the screen....!!!
Change the resolution, if you dont know how, just google it
Jul 19, 2010 | Acer V223W Monitor
I have a V223W monitor it goes to a black screen
Possibly cold solder joint or a cable needs resitting will need to take to trained technician as covers will have to come off to reflow pcb boards
Jan 04, 2010 | Acer Computers & Internet
I have a new Acer 22in v223w flickers
Check your power supply. IF it is through a UPS then try connecting directly to a main supply. If problem persists then look for a ACer service center immediately. There might be a problem with the panel.
Nov 30, 2009 | Acer 22" X223w LCD Monitor
Acer V223W monitor goes to sleep and doesn't awake
Go To Start > Programs > Accessories > System Tools > System Restore. Select "restore my computer to an earlier date". Look at the LIST of Restore points. Find the DATE when this "Security Update" was installed and Select the last date before it was installed and Follow the "Wizard" to Restore it to BEFORE the Update you think CHanged Things. Too many variables to figure out without seeing it to determine what was changed but that will correct the situation and you will not loose anything.
Aug 21, 2009 | Acer V223WBD Monitor
Driver
Here is a link to the driver you need.
http://support.acer-euro.com/drivers/monitor/v223w.html
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
May 12, 2009 | Acer V223WBD Monitor
Acer V223Wab Widescreen Lcd Monitor Blk Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
