Question about Dishwashers
MIELE DISHWASHER NEEDS A NEW KNOB
I need to replace the selector knob on a Miele Dishwasher (model G 1040). Can anyone tell me how easy this is? and how to do it?
Thanks
Simon
  • 49 Answers
Give me a couple of days and ill get back to you on that one.
do you need a part number for the knob?
Posted on Feb 19, 2008
  • anonymous111 Feb 20, 2008
    hello i could not find the service manual for removing the knob but from what i can see you should only have to pull it off.i could be wrong. one thing i am sure of is the part no for the knob from miele is 6065180
How do I turn the Miele oven on? Model is H6260BP
To turn on the oven, press the recessed On/Off button on the left below the rotary selector knob. Make sure that the system lock is off. (The display will show S 1 if it is on.) Press and release the function selector and rotary selector knobs if they are retracted. Rotate the function selector to the desired function icon (line up the dot). Then turn the selector knob to select the oven temperature. Press OK to start cooking.
Miele has the manual for the H 6260 BP oven on the product site on the Downloads tab: https://www.miele.com.au/domestic/ovens-1451.htm?mat=09514470&name=H_6260_BP . The direct link to the manual is https://www.miele.com.au/pmedia/ZGA/TX3587/10108150-000-01_10108150-01.pdf . See page 21 for a picture of the oven controls.
I hope this helps.
Oct 04, 2016 | Miele Ovens
Miele 1040 dishwasher leaking at rear
The dishwasher needs to be pulled out and the hoses checked for leaks but you should call Miele to do it. Otherwise you will void their warranty if you should do it yourself & you may also cause damage to the unit. They are very electronically advanced and expensive, as you know.
Apr 11, 2014 | Miele Dishwashers
Where is the salt container?
Usually on the base you will find a round knob. That needs to be unscrewed to get access to the salt container.
Not sure if this model does come with a water softener. Need to check.
Apr 02, 2014 | Miele G4205SC Futura Classic Dishwasher
Replacing split drain hose on Miele dishwasher, cannot see how to access connection point inside the dishwasher!
A model number would be required for specifics.
Probably need to access from bottom. Probably best to lay it on the back. I am assuming your user manual suggests tipping towards back if/when moving. If it is a miele there is probably a built in water softener and lots of water in tanks that are not easy to see until panels are removed. Side panel might be easier to be removed to allow a view of stuff.
If applicable you might want to search the web for,
2011-11-25_043923_g600__800_miele_service_manual.pdf
Jan 31, 2013 | Miele Premier-Plus Built-in Dishwasher
I have a Miele G641 dishwasher and it wont drain and it is coming up with red lights saying inlet/outlet, salt intake
One thing these guys did not point out is to turn the knob to STOP before starting this procedure (otherwise you will be ignored) Once done this works fine.
-- from the manual ----------------
Before rectifying the problem you must:
- Turn the programme selector to the "Stop" position.
- Switch the dishwasher off using the "On/Off" button.
Nov 15, 2009 | Miele 24 in. Novotronic G641 Plus Built-In...
Miele G868 built-in dishwasher water inlet problem
Pull of the program knob. Then you should find a water-intake-time-selector to the right of the axis. Take a screwdriver and turn it slightly counter clockwise one click to increase the time and vice versa.
Here's the manual:
http://www.miele.com/manuals_pdf/Residential/Dishwashers/English_manuals/Operating_Instructions/G870_us.pdf
Feb 12, 2009 | Miele 24 in. G870 Built-in Dishwasher
Miele G868 Dishwasher is dead, won't even turn on
I had a similar problem. Check the control knob that turns the machine on. At this age, it sounds like the control knob is either bad or a wire has burned off. Check to see if their is an internal fuse in the washer.
Jan 21, 2009 | Dishwashers
Miele dishwasher
My O/H found a considerable amount of gunge in the inlet pipe; that seems to have solved it! Thanks for your interest.
Enid
Jul 21, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
157 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
