Question about Toshiba Satellite M45-S331 Notebook
The DVD drive (UJ-811B) failed in my Toshiba Satellite P25-S609. I replaced it with a UJ-841S from a Toshiba Satellite M45. The drive seems to work fine once WinXP is running, but My BIOS won't boot from it. I don't see a message from BIOS saying that it found the DVD drive, so I think it won't boot because the BIOS doesn't see it. I flashed the P25 to the latest BIOS and was considering flashing the DVD drive. I read that the Toshiba's ise an inverted cable select (CS), so I need to use a Toshiba BIOS. Any ideas?
  • 177 Answers
My laptop, a Toshiba Satellite A-105, using a Matsuhita DVD ram UJ 841s. It burns Cd's but nothing is on them after it has completed the burn. It goes through the motions of burning and completing the burn...
Uninstall the Nero and restart ,
After restart again install the Nero.
Hope this helps
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 23, 2011 | Toshiba Computers & Internet
My old toshiba P25-S609 is experiencing the blue screen of death after a failed MS windows update. getting the error message STOP: C0000218 Registry File Failure. I don't have a recovery disk (don't...
Hi There,
Your best bet for the least bucks is eBay for a Retail Disc with serial number. Please keep in mind that your machine is old enough to be expecting a hard drive failure and the error code you typed above refers to 2 different types of failures. The first is that you have attached an accessory of some kind which is incompatible with XP. The second, as per Microsoft, is that it is your hard drive that has failed.
However you acquire an XP disc, when you boot from it, let it run Setup to the point where it gives you the option to Repair by pressing the R key. You will have entered a DOS environment. Select the OS you wish to repair and you'll end up at a blinking cursor. Type CHKDSK and hit Enter and CheckDisk will automatically attempt to repair the install and will tell you if the HD is beyond repair if that's the case.
Good Luck
Aug 10, 2010 | Toshiba Satellite P25-S609 Notebook
Toshiba p25-S609
Remove the battery and then wait a little then replace it.
Restart and try again.
Jan 06, 2010 | Toshiba (P000204210) Motherboard
Where i can find matshiba dvd ram uj 841s downloader
http://www.softwaredriverdownload.com/matshita_dvd_ram_uj-841s_update.html
Jul 23, 2009 | Toshiba Satellite A105 Notebook
Using recovery disk on toshiba satellite p25 when dvd doen't work
if you had your windows XP media bootable edition... use it to format you Laptop...
note: after you format your laptop your files will be deleted... so make a backup as much as possible for your important files
Feb 23, 2009 | Toshiba Satellite P25-S609 Notebook
Satellite P25-S609: Black screen, extrenal monitor works fine
I think it is the inverter to the screen that is bad. I will be trying that to see if it corrects the problem. I think the lamp is good as I do see some (very low) light at the bottom of the screen.
Feb 19, 2009 | Toshiba Satellite P25-S609 Notebook
P25-s609 display
When you say you turn it on, do any of the lights on the laptop light up? Does it make any beeps?
Have you done anything to your laptop or has anything happened that you think might have caused this?
Start off by simplifying your setup as much as possible to eliminate any outside influences.
Remove anything plugged into the laptop. Then unplug power and remove the battery. With battery out and power disconnected, hold down the power switch 15 seconds (this can clear out a corrupt BIOS).
Reconnect only AC power and try to power up. Verify your AC power has a power light lit up and all connections are snug.
If no go, try only with the battery and no AC.
Still no go, remove battery and any removable drive (CD, DVD, etc.). Connect AC power and retry boot.
If you feel comfortable removing the hard drive, remove it and retry boot.
If all drives are out, all external and internal devices removed and still no display, try removing the memory and putting it back in (reseating it).
Let me know if that helps or if you need further help.
Honest1abe
Dec 30, 2008 | Toshiba (K000006610) for Satellite P25...
Toshiba P15 S479 Laptop
I had the same problem. The AC adapter connections on the mother board had to be resoldered.
Nov 04, 2008 | Toshiba Satellite P15-S479 Notebook
Toshiba satellite P25-S607, DVD inside: Mashita UJ 811 doesn't work
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_docTOC.jsp?moid=438069&rpn=PSP20U&ct=UG&soid=470129&BV_SessionID=@@@@1849588803.1200582589@@@@&BV_EngineID=ccccadeddfdjedicgfkceghdgngdgnn.0
Here is a phone number too (800) 457-7777. Try that and also maybe the spring you are talking about came from the locking switch on the bottom under the bay, Check that and see if it still springs back for you, Hope that help you out somewhat. Thanks Bear001
and(800) 457-7777.
Jan 17, 2008 | Toshiba Satellite P25-S607 Notebook
Toshiba Satellite M45-S331 Notebook Logo
536 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
