The unit will not power up or have any response from the front panel is there like an inline fuse or something that could have blown
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
All TV sets have a fuse----
What is brand and model number of your TV?
SD TECH
Posted on Feb 01, 2010
My TV Wouldn't On
if no any power light indicator at the front of your tv that was mean the unit is dead set or no voltage that is circulating in the main board and other boards.if you can remove the rear cover of your tv, the first place to check will be the power supply board if the primary fuse was blown. if the fuse is blown with darkened color that was mean has shorted component either in the main board or in the power supply unit. if the fuse blown with clear color just replace with the same rating.
Aug 02, 2012 | Televison & Video
I have a Olevia 242-T11 and it has no blue power light, removed rear cover discovered blown fuse at power board, went to radio shack and found simular fuse 5A 250v but fuse keeps blowing out when powe
The fuse is always a protector and when it had blown a second time it is certain that there is a short or high current drain in the power circuit which exceeds the limit and so to prevent further damage or fire the fuse blows off. You need to just use a multimeter to check so as to confirm the short on the power supply unit.
Check this link for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jan 05, 2012 | Televison & Video
It just stop working wanted to no if there is a fuse in the back of the unit
If your head unit was installed properly there would be 15 amp inline fuse on the yellow power lead.
Also check your vehicles fuse panel for a blown accessory fuse.
Mar 03, 2011 | Alpine CDM-7874 CD Player
No power in cigerate lighter 1991 camry 4 cyl front wheel dr
The fuse is more than likely blown. It may have an inline fuse in the wiring harness that is blown or it may just have a fuse in the fuse block.
May 27, 2010 | 1991 Toyota Camry
Remote lights blink no response. All three lights on remote blink and no response from unit.
Fuses and/or power to unit is gone out. Find source of power and ground to unit and you'll find your problem.
Feb 01, 2010 | 2007 Toyota Camry
Dead microwave, after power surge
look for a ceramic fuse in a fuse holder. probably 15 amp or 20 amp. if this is blown (and likely is) the micro won't work at all.
Oct 16, 2009 | Microwave Ovens
Ricoh Aficio 2232c printer without power. Need to
The main fuse is close to where the cord plugs into the machine. You can follow the wires, (black white and green) to an inline fuse or the main power board.
Sep 22, 2009 | Ricoh Aficio 2232C Color Copier
Suddenly stopped working, green light on remote works, but no response from car. No locks, trunk, or start.
Could be many things, loose ground or power wire on the 561, there is an inline power fuse on the red wire leading to the control unit that may be blown. It may just need to have the remotes reprogrammed to the control unit, sometimes the control unit just stops recognizing the remotes. If you have recently had the cars battery replaced, or jump started the car, check the fuse at the control unit first.
Aug 17, 2009 | Directed Dei Valet 561r Remote...
Wont do anything, not even drain
Try unplugging the unit for 15 minutes then plug it back in. If that fails it sounds like the inline fuse which means you will have to pull out the dishwasher and look near the pump is blown and fuse needs to be replaed
May 26, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Televison & Video Logo
Top Televison & Video Experts
