Question about Alpine CDA-9856 CD Player
Getting my i-pod to play on my stereo
I have installed the cable from the back of my stereo including the ground and power wire. I plug it into my i-pod and I only have 2 options to choose from with the source button which is radio or CD. How do I get the i-pod option so I can select that one. I think it's within the function button but this button dosen't seem to do anything whether I push it or hold it in, it dosen't do anything. The i-pod charges when it is hooked up so that part works!
  • johhny jones Mar 07, 2008
    i also have the same problem i don't know how to change the mode
  • toby_bradley Jan 05, 2009
    I have the exact same problem, when I plug in my Ipod it charges but won't play! I have no idea how to fix it. Does anyone know what to do without taking my car to a professional?
If it doesnt auto-detect then you would have to go into the setup screen to switch the ipod option "on" so that the system would know that you have an ipod connected to it
Posted on Apr 09, 2008
    Champion:
  • 227 Answers
Does you deck have the Ipod Ready function print on it? It might not come with the option. If it does then just take it to a local stereo shop for advice, it should not cost any money. Goodluck.
Posted on Mar 10, 2008
I would like to add my i-pod to the receiver so i could listen to the music what kind off cable would i need
An i-pod provides a standard headphone level output. The AVR-1803 has nine RCA stereo inputs that will accept the signal from the i-pod. You need a 3.5mm stereo TRS plug on one end and two RCA plugs on the other end to connect your i-pod to your amplifier. Note: Be careful to select a 3.5 mm plug that has a slim enough plastic moulding to fit into the i-pod headphone output. On your amplifier you simply select the analogue input that you have chosen to use. Be careful of levels when you are setting up. Set the volume of your i-pod to about 50% and set the input sensitivity to zero, press play on your i-pod and gradually increase the gain on your amplifier input. Hope this helps, Don.
Dec 08, 2013 | Denon AVR-1803 Receiver
I have an Optimus STA-3500 Digital Synthesized AM/FM Stereo Receiver. If I buy an i-pod is there a place on the back of the receiver that it can be plugged into? If so, what kind of i-pod wire/cable...
It won't have "iPod" functionality but it can be played through the receiver.
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT one labeled "Phono".
Jul 25, 2011 | Optimus STA-3500 Receiver
My AV receiver turns off a couple of seconds after I turn it on. I did what the manual said, unplugged the power source and removed all of the speakers but it continues to do the same thing. Anything else...
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate me"AS THUMBS UP" Thanks
  • Jun 20, 2011 | Onkyo TX-SR606 Receiver
    I have an older model Harman Kardon AVR and have started hearing humming from the speakers that are attached to it. Is my receiver going bad or is there something else I need to do to fix this problem?
    Take care and please remember to rate "AS THUMBS UP" Thanks
  • Jun 20, 2011 | Harman Kardon AVR 85
    My nad 3020 is making a buzzing noise when i connect to peakers even when nothing else is connected to it. any solutions ?
  • Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Jun 20, 2011 | NAD Audio Players & Recorders
    The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
    1998 Chevrolet Malibu Car Stereo Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Orange
    Car Radio Accessory Switched 12v+ Wire: Yellow
    Car Radio Ground Wire: Black
    Car Radio Illumination Wire: Gray
    Car Stereo Dimmer Wire: Brown
    Car Stereo Antenna Trigger Wire: Pink
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: 4? x 6?
    Car Audio Front Speakers Location: Doors
    Left Front Speaker Positive Wire (+): Tan
    Left Front Speaker Negative Wire (-): Gray
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Dark Green
    Car Audio Rear Speakers Size: 6? x 9?
    Car Audio Rear Speakers Location: Rear Deck
    Left Rear Speaker Positive Wire (+): Brown
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Dark Blue
    Right Rear Speaker Negative Wire (-): Light Blue
    Hope this helps (remember to rate this).
    Nov 05, 2010 | 1998 Chevrolet Malibu
    Engine noise through sirius
    First check fo good ground on lighter socket sometimes manufacture's use whats called a floating ground which is one wire connecting every socket for a ground . This creates what is called a ground loop and can create noise. Instead of rewiring try an inline noise filter. check with your local car audio store. Hope this helps. If not write back.
    May 06, 2010 | Sirius Satellite Radio sp-tk2 Satellite...
    AMP GUARD ON
    I'd say go back to the guy who installed and get him to do it right. He's either left some wires exposed so they are intermittently touching, or has an open connection to one of the speakers. The amp will shut down to protect itself. He may also not have wired the speakers correctly. Some systems don't work unless both hot and ground wires run directly to each speaker. Some installers run only a hot line and use the car body for ground. At higher powers this can cause amp shutdown or keep it from working at all. In any case the installation wasn't done correctly.
    Apr 22, 2009 | Clarion M475 CD Player
    No videp playback on Pioneer AVH-P4000DVD only getting sound !!!
    Just wanted to add my 2 cents for those who might be having the issue of no video but hear audio. I was having the same problem. I had completed the bypass hack with a single throw/single pole (SPST) toggle switch. I could bypass the warning message and hit the OK button but no video. I did hear audio. I searched everywhere but solution 4 worked for me. The thing for me was that next to the black wire on the harness wasn't empty. It had a purple/white wire with some sort of filter (labeled backup camera hook to reverse gear). I tied into this wire before the filter with another wire (I chose a black wire b/c I was grounding it) and grounded it with the black wire (ground) on the harness. I now have video! Maybe the 4 pole relay hack would have worked better but I had only done the toggle switch hack. I hope this helps others and most importantly thank you Salhi.
    Mar 26, 2009 | Pioneer AVH-P4000DVD Monitor
    Alpine CDA-9856 CD Player Logo
    128 people viewed this question
    Top Alpine Car Audio & Video Experts
    xxxxxx xxx
    hoyzee1
    Jaime Hernandez
    Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
