Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Replaced timer was working now when i turn it the fridge dont turn on. its a fridgedair top freezer
  • 619 Answers
Do you mean the defrost timer or the t-stat control?
Posted on Feb 01, 2010
My fridgedaire fridge FRT856embg wont get cold on the bottom
Im not familure with this item but on the older style fridge ice would build up in the freezer blocking the air ways to the bottom half of the fridge in this case you would need to remove the food from the freezer and fridge and unplug it open the doors and let it thaw out for a day or so I wish you luck and I hope this was helpful
Dec 07, 2012 | Frigidaire FRT21H8 Top Freezer...
The fridge alarm will not stop. The fridge compartment is not cold and the freezer is just freezing. Since the problem started, have the fridge turned off for 3 days. Defrosted the freezer, turned it...
this alarm is activate if the temp. of the fridge rises and because the freezer section is full of ice form thats why affect the circulation of cold air. try to check the defrost timer if yuor unit have or heater if working if dont have defrost timer or heater try to lessen the setting of your themostat to cut of unit after reaching desired temp. or conduct weekly defrost manually.
Feb 12, 2011 | Fisher and Paykel Active Smart E522B...
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Freezer works refrigerator does not get cold not sure of the model not home right now am at work
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Jul 06, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
I have a westing house BJ414 and dont seen to be getting much air flow into the fridge section? the fan is runnong aand the freezer is reaching temp?
maybe too much food in top part of fridge. Cold air comes from top of fridge near light. Can you feel cold air coming from there? Put a fridge thermometer in the top section-they only cost a few $ from kmart etc -the temp should be 2-4 deg C. My thermostat is turned to warmest setting and its still in that range. Does fridge cycle on and off every 1/2hr or so? If it runs nonstop, it may be the freezer section is all frosted up, probably coz the defrost timer has stopped working or else the defrost element has burned out. Both can be easily replaced by you.
Apr 23, 2010 | Westinghouse Refrigerators
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
My bottom fridge is not getting cold but my top freezer works
The air circulation is neede to prevent this Make sure it's the freezer fan you hear running.
The fridge gets its cold air from the freezer through a vent(damper)between the freezer and fridge.The fan in the freezer blows air throughit. There is a flap you adjust with thefridge temp. control. Make sure it's opening and closing when you adjust thefridge temp ..
If the evaporator coils behind the back panel of the freezerare icing up because of auto defrost failure that will stop the circulation ofcold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
How to check stuff>
Aug 16, 2009 | Frigidaire FRT18S6AW Top Freezer...
I have a fridgedaire fridge the freezer is on top. And it is not freezing i changed the defrost switch and the timer and it is still not freezing. What do you think it is?
defrost has nothing to do with freezing.its for thawing the frost off the evap coils. are the coils in the freezer frosty? if the fans are running and the compressor is running and no frost on coils then freon is leaking or compr. valves are shot.
Jun 09, 2009 | Refrigerators
Top half of fridge and freezer are not working
I need that model number of the Frigidaire refrigerator so I will able to help you better. Thanks, Sea Breeze Here is my email should you not be able to contact me. seabreezehvac@yahoo.com
Apr 21, 2009 | Refrigerators
My LG LRBN20514ST Fridge is not cooling
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
