Question about HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 won't let me change print margins
HP PSC 1510 won't let me change print margin. The left margin is set for .25 and the left is set for .5. I am trying to print from adobe reader. I went into page setup and changed the margins to 0, but still prints incorrectly.
  • 61 Answers
SOURCE: HP PSC 1510 PRINTER
first ckeck out the your cartages are ok and then when you start the printer them it print the alignment page then put it in the scanner and scan it your problem will be surually solved
Posted on Jul 26, 2008
SOURCE: HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Posted on Dec 11, 2008
CompuGuy44
  • 432 Answers
SOURCE: Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Posted on Dec 19, 2008
  • 124 Answers
SOURCE: Expand Printable Area
Instead of print select print preview. Select printer options select scale to fit.
You can also setup in hp printer software just select paper size & or scale to fit.
Posted on Mar 08, 2009
Nikhil Gedam
  • 87 Answers
SOURCE: Setting margins on printer
Well, by now you may have found the solution, however, make sure that in MS WORD under File > Page Setup > A4 is selected, and if you still this prompt (error), just click on OK and proceed with printing.
The Laserjet Printers are capable to print upto 5mms from the edge of the border.
Regards,
Nikhil
Posted on Sep 16, 2009
WON'T PRINT TO MAXIMUM PRINT AREA
You should change the margins in the word document before you print to 0.5 mm on all sides and remove header and footer.
May 02, 2012 | HP Officejet 6500 Wireless All-in-One...
HP 1510 cuts off print on right margin.
Hi bpbpbp
We'll start with the easy things!
1. Make sure the paper guide is properly pushed up to each edge of the paper.
2. Perform a printer head clean. (If you need detailed instructions on how to do this then please get beck to me).
Let me know you get on and if you need further assistance.
Scott.
Feb 01, 2010 | HP PSC 1510 All-In-One InkJet Printer
Printing a full page 'background' (design) with no margins
No. The official minimum print margins are as follows
print margin specifications
Top (leading edge)
Bottom (trailing edge)1
Left
Right
Sheet Paper
U.S. letter
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. legal
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. executive
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
ISO A4
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
ISO A5
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
Sep 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
On HP K5400 printer the Left margin for #10
See an online manual with instructions to change the print settings here., then open the document program that has the addresses in it and use the print preview and page setup to adjust the margins for the printing to 1/4', if they'll go down that low.
Jul 10, 2009 | HP Officejet Pro K5400dtn Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Mar 08, 2009 | HP PSC 1510 All-In-One InkJet Printer
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
HP PCS 750 cuts off bottom of 8 1/2 X 11 page when printing. Auto reduces page.I need 100%.
The PSC 750 cannot print a full borderless page, it requires a bottom margin of 0.46", a top margin of 0.08" and side margins of 0.25" when printing on 8.5x11 pages.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jul 04, 2008 | Office Equipment & Supplies
Landscape print gives dots or lines in the upper margin
unplog your printer.clean your printhead of the printer by a tissue paper.
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Margin problem
Problem---Printer prints email on the very edge of the paper and leaves off the first 3 letters of every word down the edge of that margin. If you have Windows Live Mail forget trying to fix it from there. Clicking File will not give you the page setup option you are looking for. Go to the bottom of the screen, click "all programs", look for and click "Internet Explorer", click File, click "page setup". A screen comes up in which you can change the margins. The left margin is probably set on .25. Change it to .75. Okay. Go back and run a test email.
Dec 19, 2007 | HP Photosmart 7450 InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
641 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
