Question about Sharp Office Equipment & Supplies
I have a sharpUXB7000fax and printer but lost my owners manual hadt to replaceee ink cartridge and now it won t print just says check print cariege
  • warrior0810 Feb 01, 2010
    can I get an owners manul mailed to me for the Sharpmodo;e #UXB7000
  • 17,970 Answers
This message means:
- CHANGE CARTRIDGE, appears after you install or replace the print cartdridge; or
- CHECK CARTRIDGE, the print cartdridge is missing and must be installed or is not installed correctly.
Here you can find the Sharp UX-B700 User Guide, check the page 19 for details about "installing the print cartridge".
Hope helps.
Posted on Feb 01, 2010
  • Sharp Master
  • 3,247 Answers
Unfortunately I am not able to find any device made by sharp that matches the model no. UXB7000. The closest I can find is UX-B700 which is a Fax machine.
This is the user manual for it. If this is the model of your fax machine then you can check whether you have missed anything when replacing the print cartridge.
http://www.tradenet.sharp.co.uk/files/Personal_Products_%28Copier%2CPrinter%2CFax%29/Facsimile/UXB700/UXB700619.pdf
Hope this will help you. If this is not the model then please provide the model number after checking carefully. Happy to help.
  • Sam Feb 02, 2010
    I am trying to help you out and finding the manual you need. But you will have to help me identify the fax/ printer correctly. If UX-B7000 exists then it must be a very unique machine.
    Please send me the model number and manufacturer name of the Ink cartridge that you have used. That might help me find the fax/ printer that you have. Is this used in Europe?
    It would be better not to rate the solution before you have given me a chance to find the correct product that you have got.
The color of my print is very pink and yellow with no blue
If your printer has 3 colored ink cartridges, your cyan (blue) cartridge is empty. Replace it with a new one. If your printer has just one colored ink cartridge, the blue section of it is empty. Replace the cartridge with a new one. You'll find the correct cartridge (normally a number) in the owners manual and/or on the cartridge itself. See the owners manual for instructions on where the cartridges are located and how to replace them.
Oct 12, 2014 | HP Photosmart C6180 All-In-One InkJet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
My epson DX8400 won't print yellow at all, green prints as blue, red prints pink on certain documents i've created. I have printed an email off today which printed all the colours perfectly??
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Aug 22, 2011 | Office Equipment & Supplies
We have just put a new black ink cartridge in our printer and now it won't print. The computer says it is error# 5200 and to see the user guide. The manuals don;t have any info to help. I have tried...
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
Jul 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
My printer won't print.
There are different things to consider if your printer is not printing your document
1. Check if the printer is on
2. Check if the cable from your printer is properly connected to the tower or your pc.
3. Check if your ink cartridges are not empty ( note: most printers will not print if one of the ink cartridge is empty)
4. Check for the error message that appears on your screen every time that your printer fails to print the document ( note: this will help you isolate problem)
5. You can use this link to download the manual for your printer ( this include steps to check your printer settings )
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=303753
May 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
Why is my printer only printing color and not black ink while there is a black ink cartridge installed? When I looked at the printer after printing the alignment page, it said alignment problem but there...
This happened to me as well. Take your alignment page (or print another one) and put it in your scanner. The AIO printer will use the scanned alignment page to reconfigure your alignment.
Oct 15, 2010 | Dell 926 All-In-One InkJet Printer
Printer goes thru the motions but does not print.have not used in a while. the ink cartridges look clean and the chart shows plenty of ink when i print the allignment page(it's blank twice) the display...
If the printer has been unused for a considerable time the cartridges may have become blocked with dried ink.
Remove the cartridge(s). Take a slightly dampened cotton bud or piece of kitchen paper and carefully wipe the copper coloured surface on the cartridge(s). Then wipe with a dry piece of kitchen paper.
Re-insert the cartridge(s) and perform the print head cleaning function in your printer control panel.
Now try printing.
Mar 26, 2010 | Office Equipment & Supplies
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
48 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
