Question about Dell Computers & Internet
Power supply and battery is good, when plugging in the power supply to the outlet the blue light comes on, then when plugging the power supply into the laptop the blue light goes out and the laptop has no power
  • 2,229 Answers
Sounds like there is a short on the motherboard that is keeping it from starting or even accepting external power.
My suggestion: a new motherboard is probably in order.
Posted on Feb 01, 2010
Completely dead acer chromebook..working fine on battery when plugged in died
So did you unplug the power supply and try to restart it? When you plugged the power supply in did the power light come on on the power supply showing it was working? Blue light usually.
Sep 23, 2016 | Acer Computers & Internet
No power supply on cpu in Acer Aspire One PC Notebook
If the power will come from the battery, make sure the battery is fully charged. If it's plugged in to a wall outlet, unplug both ends, make sure the outlet works, count to 10, plug everything back in. I hope the solution is as simple as this. Good luck!
May 21, 2012 | Acer Aspire One PC Notebook
Even when laptop is plugged into an electrical outlet, it will suddenly think it is not and drain the battery power..the indicator lights will flash and battery power will drain.
There may be a fault in the laptop's power supply adapter.
Try testing its rated output voltage versus the actual with a multimeter.
If the adapter comes in 2 sections, 1 cord from the wall to the adapter, and then the adapter to the laptop, be sure to test both sections.
Replace the adapter if required.
Also check that the connection socket where the power adapter plugs into the laptop is not loose and preventing proper electrical contact.
Good luck.
Feb 28, 2011 | 4D NSpire Power Supply NSP-300P4D 300W...
Our canon MP560 printer will not turn on - it was plugged into a surge protector and we have tried moving the plug to alternate outlets just to make sure that wasn't the problem...help!
This is what worked for me. I had a similar setup and could not get the printer to turn on. Remove the power supply from the back of the machine. It is a very simple process: pull apart two small plastic connectors with your fingers to remove power supply. Disconnect internal blue cable from power supply.
Replug blue cable and be sure it is plugged in tight.
Push power supply back into place, be careful of blue cable when pushing it back into printer.
Plug in and printer just may work...good luck!
Jun 28, 2010 | Canon MP560 All-In-One InkJet Printer
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Was using the laptop (dv6426us) and it just cut off. Was plugged into outlet with power supply, no warning messages prior to that. Now it will not power on at all, no lights, no beeps, nothing. If I unplug...
First, measure the voltage coming out of the power supply. If it is good (specs will be on the power brick itself.) then this sounds like a short on the motherboard. To eliminate all else, remove anything that is removable (hard drive, CD/DVD and RAM). Leave the battery out also. Plug in the power supply and see if it beeps. If not, you have a bad motherboard. If it does beep, replace the ram. At that point, you should be able to see POST. If you get nothing, it is the ram. Keep adding until the problem resurfaces. The last item added is the culprit.
Good luck.
Aug 12, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Pc won't power ( turn on)
The green light is most likely your lan card/port. If the cord/outlet are sparking when you plug it in, I would say try plugging something else into that socket, if you get the same spark, I'd call an electrician. Also try plugging the pc into a different outlet. As far as the computer, if its not the outlet then it is the power supply, your motherboard may be fried in the process but if this isn't an issue with that outlet, then you should take it in to a shop.
Mar 16, 2009 | HP Pavilion a450n PC Desktop
Hello, I have a Lacie 330770 250 GB hard drive.  It does not respond when I plug it into the outlet.  I have tried several different outlets in different rooms, and neither the green light on the power...
If the green light on your LaCie power supply does not light, you likely have a bad power supply. You can buy a new one from LaCie. If you are purchasing a new power supply from LaCie ask for the higher wattage unit. LaCie upgraded this a while back.
Jan 26, 2009 | LaCie (300770) 250 GB Hard Drive
My HP ALL IN ONE would not come on when press power button. Blue light does not come on either.
try connecting the printer on another power supply and see if it will power on if not try another power cable with same specs if you have to check if this only a problem with the cable or with the printer itself..
If still printer not powering up , have it check by the manufacturer or replace it from them if still under warranty...
Hope that helps.......
Aug 05, 2008 | HP Office Equipment & Supplies
HP OfficeJet 6210 printer
unplug all the cables ang plug them back in
also try reseating the cartridges
May 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Computers & Internet Logo
43 people viewed this question
Alun Cox
