Question about GE Dryers
My timer is not working. the turner is turning to loose. it does not click while turning. the start button does not begin.
  • 619 Answers
Common problem with the GE dryers is the start button will crack and will not catch the stem. Try changing the start knob over with the heat selection knob and see if you can start then.
Posted on Feb 01, 2010
How do you set the clock for a 1061978 oxo timer
This is the only timer model OXO doesn't provide for download on their site. But I also own this timer, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Sep 15, 2013 | Oxo Hardware & Accessories
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
The freezer defrost light is on - we moved the freezer!!! a solution on your site was to turner the timer until the motor was heard to 'kick in' - there is no manual with this freezer...
Whooa,
You can not blame the people who are trying to help.
The more information you can give the better the diagnosis.
This , from your information, sounds like the defrost timer has stopped half way through it's cycle. A new defrost timer may be needed.
Find the defrost timer, advance the motor forward until it clicks. the compressor should now start and cool the fridge.
Mar 30, 2011 | Refrigerators
Is the button NC or NO? I have it currently wired this way but still it does not work and I'm using a switch not a button. Any suggestion?
The switch is OFF or NO normally open
See wiring diagram at following link
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
The way the timer works is this::
You click switch ON
When you turn switch OFF, the Dayton begins the timing sequence
The Dayton turns on the circuit going to load for 1/2 second => 5 minutes depending on model of Dayton timer
Grainger sells 120V push buttons if you don't want to turn the switch on-and-off each time
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=push+button+switch&op=search&Ntt=push+button+switch&N=0&sst=subset
http://www.grainger.com/Grainger/IDEAL-Push-Button-1XWT9?Pid=search
Oct 12, 2010 | Amperite Dayton Solid State Timer On Delay...
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
I have Platinum 18 on windows Vista. For some reason the page turner button on the bottom of the screen says For Help press f1 (not go to page or add pages). So I cannot turn pages unless I do it by going...
This worked for me ... I got this from going through the Help/Online Help from within the program.
Complete the following steps:
With a multi-page project open on the program workspace, click File in the menu bar and choose Print Preview.
In the Print Preview window that appears, click the Zoom In button and click Close to return to the project. The Page Turner button will now display.
Jun 20, 2010 | Broderbund PrintMaster Platinum Version 18
Status bar appears but page turner is missing.
Aug 28, 2009 | Broderbund The Print Shop 22 Deluxe Full...
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Duet Sport dryer does not start. When you press the start button, it goes through the process but never begins.
If it sounds like the timers clicking but not turning on you might have a bad thermal fuse.
Jul 08, 2008 | Whirlpool Dryers
Dryers Logo
145 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
