Question about Husqvarna Chain Saw 20" Bar
Fuel mix for Husquarna 61 - Husqvarna Chain Saw 20" Bar
    President:
  • 2,220 Answers
  • dontbother10
    dontbother10 Feb 01, 2010
    I gallon premium fuel to 2.6 ounces of quality 2-cycle oil
How to restrict husquarna cr50
Not really a lot you can do to a cr50 apart from restrictions to its fuel and air mix...but I must warn you this will be at detriment to your engine....
Just try to ride slower or learn on something smaller and not as well set up ,,,,such as a midi Moto 50cc dirt bike
Oct 15, 2014 | 2011 Husqvarna TE511
Whats the best premix gas to use on a Husquarna 125B hand held Blower
The best mix to use is what's recommended in the manual but in most cases blowers use a 50:1 mix. The difference from 40:1 to 50:1 is negligible but you have to use what the motor is built for. Too much oil causes a loss of power because the gas won't burn efficiently. Too little oil and you risk damaging your piston or cylinder.
Feb 22, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Would like to know oil gas mix ratio for the 61 huskvarna
Husqvarna two stroke oil mixed at 50-1, other makes of two stroke oil mix at 25-1, always try to use Husqvarna oil.
Aug 11, 2011 | Husqvarna Garden
I have an old 61 rancher, It has not been started in over 5 years. trying to crank it over,but the starter cord only will come out about 6 inches until it hits heavy resistance. If I remove the plug it...
It sounds like a high compression issue, there may be a fair amount of oil sitting in the cylinder, i am sure once it starts it will clear this and run as normal, dribble a small amount of fuel oil mix through the open plug hole, now crank the engine a few times, refit the plug and try again.
May 02, 2011 | Husqvarna Models 61-66, 266, 268, 272
What is the correct fuel mix.? for husq.61 model
50:1 according to the specs. Here is the helpful link.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/01ec47be5550bbce88256d5a005a3315?OpenDocument
Oct 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
28cc Gas Line Trimmer: I have a husquarna 125L. After it started it stal...
its not getting enough fuel. take the carb apart and clean it good. you can use a twist tie stripped off to clean the really fine holes or a wire brush wire. also you can burn the screen off in the carb. pull it out, burn off and use a drill bit or something similar to reinstall it.
May 03, 2010 | Garden
I have a husquarna 357xp I need to know to fuel,air and T adjusments
The Husky workshop manual on Appendix A (USA) says "H" 3/4 turn CCW from lightly seated. "L" 1.5 turns CCW from lightly seated.
Page 36 (every other nation on earth) 1 turn CCW from lightly seated for both the "H & L" needles.
There is no recommended initial "T" setting. (from manual) "The idling speed is correctly set when the engine runs smoothly in all positions and there is a clear margin to the speed at which the chain starts to move".
These are initial settings and the saw needs to be adjusted for performance. Start with a clean air filter and a fresh fuel mix @ 50:1 per Husky (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
This explains performance carburetor adjustment better than I can:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I hope you found this post helpful.
Lou
Jan 15, 2010 | Husqvarna Chain Saw 20" Bar
WHY THE SOLVE THE PROBLEM
with mixing, get the bass right, then add the piano/pad sounds then bring up the drums til it sounds good.
Nov 21, 2009 | Casio CTK810 61 Key Keyboard
What is the propper oil mix for model 61 chainsaw?
Fuel/Oil mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Today most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 15, 2009 | Garden
Husqvarna Chain Saw 20" Bar Logo
145 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
