Question about Polaroid T737 Digital Camera
Camera turns on for a few seconds, then off.
Polaroid t737 unresponsive. Camera powers up, shows the Polaroid logo in LCD screen, then turns off. Battery is fully charged. Happens with or without SD card installed.Camera took pictures OK. Problem occurred after downloading pictures to windows 2000 computer. User manual said driver not needed for Windows 2000 operating system.
  • 5 more comments
  • car nut Feb 18, 2008
    Fixed the problem by gently tapping the camera when I turned it on. Works for now.
  • Anonymous Mar 05, 2008
    had the same problem (camera turned off after turning on (battery full)) --yes, if I knocked it lightly on the table top after turning it on, the camera worked again.
    GZ, Connecticut
  • DarkLilAngel Mar 28, 2008
    Mine does the same thing...I tried to "tap" on it but it wont work! My birthday is sunday And I need pics!!!!!
  • Anonymous Jun 25, 2008
    Same problem. Believe it or not, gentel tapping on the side of hte lense fixed it. Go figure.
  • hunh Oct 20, 2008
    Got the same symptoms...tapping, slapping nor pounding does nothing.
  • ivanov_andre Apr 14, 2009
  • lij2 Apr 22, 2009
    same problem. fully charged battery didn't help. i noticed the lens cover was stuck in a slightly open position. i banged the side as others here recommended, and that worked. i suspect it was a problem all along with the mechanical lens being stuck.
I had to bang my camera against the door jam a little hard and that did the trick.
question; can that machanisn be safely lubricated?
Posted on Jun 26, 2009
The problem all of you are having is that when turned on the lens doesnt quite come all the way out so the sensor tells the camera to shut off after a few seconds. dont "tap, slam, pound on table any more . all you need to do is grab the lens and give it a slight pull. First day i had mine it fell off my lap into some soft dirt and i had the same problem, kinda anoying isnt it, but good camera.
Posted on Jan 13, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
Posted on Feb 21, 2008
Tip
T737 Black Screen Help
I have just recieved a t737 Digital Camera as a X-mas present. I charged the battery for it and after the battery was fully charged i put it in the camera. But the LCD screen is ptich black dark and lens is open. What do i do?
on Jan 06, 2008 | Polaroid T737 Digital Camera
What does it mean if internal memory is full? cannot take pictures. changed memory card but still says internal memory is full polaroid t737 digital camera
To get your card to work, you must get rid of the pic's in the internal memory. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions. After that, your card should work properly.
Feb 22, 2011 | Polaroid T737 Digital Camera
Polaroid t737 camera.what to do when the LCD comes on for a few seconds and then the camera shuts back down. the lens stays closed and doesnt move. Is there anything that can be done?
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Oct 24, 2009 | Polaroid T737 Digital Camera
I have a Polaroid t737. I plugged it into a Mac OS X to try and download pictures, and the drive never showed up. Therefore I unplugged it from the computer. Now when I push power, the LCD comes on for a...
It is always a good idea to plug in these units before turning it on and turning it off before unplugging it.
What can happen is something like this:
When you plug in a live camera or anything else, you may get a voltage spike or some voltage going to the wrong place and damaging the unit, or the computer. The same is when you unplug it.
Taking precautions will prevent damage to the very intricate and sensitive circuits.
This could be what happened to you and your camera.
You could try to get the camera to the menus, if possible and set it to defaults.
For instance: Just using a keyboard on a computer with voltage on your person from walking across a carpet can blow out your computer and ruin it. If you have static problems in your work area, you should use a ground strip. Better safe than sorry!!
Sep 01, 2009 | Polaroid T737 Digital Camera
I have a Polaroid t737 and the lcd display has been cracked and now I can't see what it being taken. The camera seems to work fine but the lcd does not. Can it be replaced?
First is it under warranty? If it is make use of it. If you did not buy a extended warranty, you can contact Polaroid and get a quote or you may try going through the vendor you purchased your camera from. What you will find out is the cost is going to exceed half of what your camera is worth. Some places will offer you a refurbished camera in exchange for yours and a modest price of maybe 50% of the new replacement cost.
I need a battery for a Polaroid t737 digital camera
To purchase accessories for digital and digital video camera model numbers beginning with: a, i, Ion, izone, m, t, CAA-04030S, Studio 4, x530, PDC (except PhotoMAX PDC models listed above) and Polaroid Pixie cameras, contact the number listed below-- Polaroid Digital Camera Support
USA / Canada: 1- 877 - 388 - 3779
Hours (EST): Mon-Fri 10am - 7pm, Sat 10am-4pm
Available accessories include -- batteries, USB and video cables, image editing software and other items that were included when you purchased your camera. Note: Accessories may not be available for some older camera models.
Dec 30, 2008 | Polaroid T737 Digital Camera
Cant find a battery!
I have just put a battery on ebay for it. I just don't have the recharger pack. http://cgi.ebay.com/Polaroid-t737-camera-battery_W0QQitemZ320290362171QQihZ011QQcategoryZ43447QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or go to ebay and type in polaroid t737 battery
Jul 27, 2008 | Polaroid T737 Digital Camera
Lens buzzing Polaroid T737
Your lens is stuck. You should contact the buyer and ask for a warranty or replacement. If they can't, try getting a service manual and it shold tell you how to fix it.
Jun 01, 2008 | Polaroid T737 Digital Camera
T737
Ihave the same problem. Its annoying. When you turn it on does it make a buzzing noise? Cause that's what mine does. Except I never dropped my camera. It just goes to the Polaroid screen and then turns off. I'm wishing I wouldve bought a different camera :( Sorry I can't help..
Mar 28, 2008 | Polaroid T737 Digital Camera
Polaroid T737 Digital Camera Logo
490 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
