Question about Whirlpool LER5636P Electric Dryer
Cleaning Whirpool Ultimate Care II
I have the above machine for over a year now. How do I open the interior cabinet to remove/clean the accumulated lint.
  • Gary Davd
    Gary Davd May 11, 2010
    two screws under the lint door and pop up top remove front and drum
    Genius:
  • 1,073 Answers
Once that you have lifted the top up you can remove the two screws that are down inside the frount panel about three inches, pull out on the frount panel and swing to the side, if the lint buildup is large then check the vent to the dryer for any kink a shop vack works great for this chore
Posted on Apr 30, 2008
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Whirpool Ultimate Care II washer - drips
    Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
    If that does not solve the leak through problem,the water inlet valve will have to be replaced.
    Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
    http://appliancejunk.com/forums/index.php?topic=5191.0
    Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    How do I remove the rear panel of the washing machine to access the inside?
    You do not remove the rear panel.
    This video will show how to open the cabinet.
    Disregard the other steps after cabinet removal.
    Mar 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Water leaking onto floor from under washing machine
    first off check for punctures in hoses,
    a leaking pump (common issue, youll see water dripping from pump area)
    search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
    Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care 2 leak after wash cycle
    Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
    Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II keeps taking water.
    ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
    Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirpool Ultimate Care II -- No Drain/No Spin
    not a major project..remove 2 screws in rear of console lift and roll console back ..remove plug in cabinet to switch and pop clips out each corner ..cabinet can then be lened forward and removed allowing access to switch
    Aug 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Leaks water from the bottom
    Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
    Oct 08, 2006 | Whirlpool Ultimate Care II GSW9650LW Top...
    Whirlpool LER5636P Electric Dryer Logo
    77 people viewed this question
    Top Whirlpool Dryers Experts
    Tim Whalen
    Sal De
    Craig Butler
    Craig Butler
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
