Question about D-Link DGL-4100 Router (DGL4100)
Works but slow due to intermittent freezing of data transfer. DGL-4100 connected to SB5100. WAN LED is always blinking no matter what. When the data is transferring its fast but off and on data transfer freeezing makes it slow. SB5100 worked *fine* with 15 year old router which died. Tried Linksys BEFSR41before the DGL-4100. Had exact same problem. Thought it was the Linksys which is why I returned it and got the DGL-4100.
Try one or both of these:
Turn off 'Always Broadcast' for DHCP server
Turn off 'Use unicasting' for DHCP WAN Mode
Posted on Feb 05, 2010
Wan link had to be rerouted but is very slow performance what should I do
Why would you be changing the WAN? I would just restore to default settings and only adjust LAN settings.
Sep 20, 2013 | D-Link DGL-4100 Router (DGL4100)
I have a switch Dlink (DES-3026). All the status LEDs are blinking together with orange color. Is there any problem in that?
Blinking LEDs show data activity (Send & Receive) at the connected ports. So, there is no problem as long as the switch is performing well
Good Luck!
CreativeTECH
Feb 01, 2011 | D-Link Computers & Internet
Route multiple static WAN IP's to LAN IP's
the router has to be set up as a "pass through" device if your ISP has given you a static address pack.
Apr 20, 2010 | D-Link DGL-4100 Router (DGL4100)
Network connects without router. Install router
is your router powered? make sure your router is powered properly.
are you connecting your computer to the LAN ports? (the ones with a number not the one that say WAN? connect your computer to one of the LAN numbered ports and check to see if you get a green light on the front pannel. if you don't have green light, try a different port until, if you run out of ports and still no green light try a different cable.
have you by any chance disable your lan ports? I don't know if it is possible on your router to disable some ports, if that's the case is better to start fresh and simply reset your router by pressing a reset button for a minute while your router is getting powered and retest to see if you a green light on the lan port where you are connecting your computer.
if all this fails, it's very likely that your router has died. replaced accordingly.
Apr 04, 2010 | D-Link DGL-4100 Router (DGL4100)
Can't connect Motorola sb5100 to a Linksys wrt54g
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please Rate
Jan 29, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
D-Link DGS-2208 only works through Hub uplink but not router?
i think it it ehternet cable problem.
when u connect switch to swith it is twisted pair but when u connect router to switch then straight.
Dec 31, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Sony TV Model Number: KV-27FS100L No Power 1. Stand By LED Blinking Three Blinks No PowerIntermittent. 2. Stand By LED Blinking Three Blinks No Power Intermittent. 3. Stand By LED Blinking Two Blinks No...
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Apr 07, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
Oct 02, 2008 | D-Link DGL-4100 Router (DGL4100)
Dropping about half rx packets
proably that bad roghter not best best is linksys made by cisco ther new one n so fast 20 times of any others ok cheak online for yours see if u have a frimware or updates avb for that unit from ther site ok half duplx 10 mb sec still super fast then any network can offer u thx nick
Feb 06, 2008 | D-Link DGL-4100 Router (DGL4100)
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Open Questions:
D-Link DGL-4100 Router (DGL4100) Logo
204 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
