Knocking sound when drum turns,drum turns slow and cloths are still drinched, even without clothes it operates the same
  • 1 more comment
  • joshramer Feb 02, 2010
    i had to take the drum out, its a front load washer, the tri armed bracket that is bolted to the drum is broke in two spots, i cant seem to get the bolts loose to replace the part, are those bolts reverse thread by any chance?
    its model # GLTF1670ASO
    its a Frigidaire
  • 291 Answers
I suspect you have a broken weld or rivet between your inner tub and the brake, spider assembly, or drum shaft. If you reach into the drum when it is empty, and turn the drum by hand, see if you can hear the knocking noise from the middle of the back of the inner drum. If this is where the noise is coming from, your machine is not worth repairing. If the noise is coming from somewhere else, you could have something in your outer tub that is hitting the tub. Quite involved to get at on most models and highly unlikely anyway. If none of these help you, then get me the model number and brand and I will see what else could be the problem. Good Luck, Appliance Specialists
Posted on Feb 02, 2010
  • Washing Mach... Master
  • 8,220 Answers
Could be a slow drain or clogged pump filter, the knocking could simply be a displaced damper.It all goes south if the water won't drain properly, that makes for some weird noises. Inpossible to know for sure without doing some checks. If you have an error posted then that will give a clue. Here are a few error codes:
1)Water fill problem: water too more than 10 minutes to
fill to desired level sometimes indicated as a LF/IE or
long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill.
2)Excessive vibration: noisy, knocking noises. bad damper,bearing or broken trunnion.
3)Dispenser drawer open/detergent in wrong compartment:
washer will not operate with drawer open or cleaning
products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged
drain usually indicated a an LD/DE if a code is given
(long drain)
5)Drum overfilled: usually cased by sediment in the water
level pressure sensing tube going up to the main control.
6)Door open, Door not latched, clothes keeping door from
completly closing.
7)Cold water does not enter washer: hoses connected backwards
8)Oversudsing: Wrong Detergent, turbidity monitors pick up
particles in the water and judge soil content then the
washer allows for extra time to wash the clothes, if the
wrong detergent is in there the machine thinks that is too
much and declares a suds error.
9)Locked motor: error LE,loose connection,broken
wire/hallsensor, motor overheated/failed.
10)Heating error, hE, the thermister/heater is out.
Posted on Feb 01, 2010
  • 3 more comments
  • Dan Webster
    Dan Webster Feb 01, 2010
    1)Water fill problem: water took more than 10 minutes to
    long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
    2)Excessive vibration: noisy,roar, knocking noises. Bad damper,bearing or broken trunnion. no error code
    drain usually indicated as a LD/DE, if a code is given
    (long drain/drain error) Clear pump of objects
    5)Drum overfilled: usually caused by sediment in the water
    level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
    6)Door open, Door not latched, clothes/objects keeping door from completely closing. Tighten door latch, add washers if necessary to make good contact and close door tighter in case of leaks.
    7)Cold water does not enter washer: hoses connected backwards. Oops.
    8)Over sudsing: Wrong Detergent, turbidity monitors pick up
    much and declares a suds error. Remove detergent, retry
    10)Water heating error, hE, the termister/heater is out.
  • Dan Webster
    Dan Webster Feb 02, 2010
    I might have a manual on hand I can give you if you provide the model number.
    AFFINITY
    DUET
    LG
    Samsung
  • Dan Webster
  • Dan Webster
    Don't know if they are left hand thread or not. Never replaced one.
  • Dan Webster
    Dan Webster Feb 24, 2010
    How is the repair going? Did you figure out the problem?
Knocking from the drum
You really should realize that when clothes get wet, they get heavy. If those heavy clothes are sticking to one place on the drum it will be out of balance and knock at the sides of the washer. If this happens, simply open the door (not when the washer is full of water, of course) and the drum will stop spinning. Just spread the wet stuff around the drum surface and close the door...voila!
Jan 12, 2013 | Electrolux Washing Machines
Drum turns very little
Sounds like you have a belt that is one size too big
Jan 08, 2013 | Crosley CDE6000 Electric Dryer
Maytag Performa PYE2200AYW drum turns until I put clothes in it, then it slows and stops.
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to
May 29, 2012 | Maytag Dryers
Dryer is making a"knocking" sound
drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dec 25, 2010 | Dryers
Banging sound in spin cycle.
If this is a front loading machine it could be the rear bearing or the spider bracket could be broke.You will need to take the machine apart to finf out which it is
Jun 27, 2009 | Frigidaire Washing Machines
Sounds like a jet engine at full spin cycle
These things are notorious for sucking clothing under the the drum , it could cause it to be noisy spin slow and have drain problems . This is such a poor design . Try removing the drum and see if there is an article of clothing under it , mine sucked up a mans large shirt . Even if the drum seems to spin freely it still could be the problem .
Mar 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Jul 14, 2008 | Kenmore 23822 Top Load Washer
Have to dry close twice on automatic, or once on timed. Random triple beeps.
Sounds like the drum belt has broken. It's connected around the drum and motor pulley. Without the belt turning the drum it will be near to impossible to dry the clothes, Hope this helps, Sea Breeze
Oct 28, 2007 | Whirlpool GEW9250 Electric Dryer
My washer machine is making a knocking sound
Try balancing the clothes evenly,if that not the problem,the balancing ring at the very top is either broken or a snap ring or rings are off.
Jan 21, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
