Question about Maytag Performa PAV3200
My matag washing machine will spin but not agitate
    Problem Solver:
  • 15 Answers
On Matag top loaders the motor runs in one direction to agitate and reverses to spin. The timer controls the direction.
Also, the water level switch must be tripped (satified that there is water at the proper level) to agitate, it will allways spin no matter what the water level is as long as you set the timer to spin.
Posted on Feb 05, 2010
  • 714 Answers
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Posted on Feb 01, 2010
4 Suggested Answers
  • 4102 Answers
SOURCE: Maytag washer
Hi the problem will be the belt has become streched dont keep trying to use the machine as this will cause the motor to fail usually it is the back of the machine that will need to come off once this is off you will see how the belt comes off it is really easy to do and most people who can use spanners can do this with no problem.
I would say it is the back that comes off the best thing to do is take the belt off and take it to repair shop so they can order you the correct belt.
Make sure you get the correct make and model number as their are several different belts for this make of washer.
Let me know if you need anymore help ill be glad to help
Posted on Dec 04, 2007
SOURCE: where is the fuse located on matag washer LATxxx machine filled
I located the fuse all by myself, the fuse was OK, It happens to be the safety system for the lid. After the machine fills up and it doesn't go into the cycle, I just get a small scerw driver and puch on the latch.
Posted on Jan 24, 2009
  • 126 Answers
SOURCE: My maytag washing machine spins but won't agitate.
sound like the agitator motor went out the way to fix this is to take the agitator out and replace it along with the motor
Posted on Sep 01, 2009
Ge washer whre5550k2ww tub wont spin
It may be the rotor position sensor. i used you tube tutorials. There are many washers that are the same, but different brand names. Matag, whirlpool, kenmore elite oasis, all the same and parts. I got lucky and a cleaning hack. It was to clean between the tob and thre shell. This is located up under where you cannot see, use a mirror and look wherr your detergent, fabric softer and bleach dispensers are. And i found a tutorial on diagnosting code that will do it for you. I think it was holding a cycle 5x for 5 seconds and it will tell you. Whats wrong, Good Luck
Jun 27, 2016 | GE Washing Machines
Maytag washer
Dec 04, 2007 | Maytag MAV7600 Top Load Washer
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
I have a Matag Performa washing machine when it gets to the spin cycle it won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Washing Machines
The Matag Neptune Washer unit will not do a spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
Matag washer LAT8034 will not agitate? will fill with water, will spin and rinse, will not agitate to wash clothers.
Make sure that the agitator is not loose. It can also have the spline stripped and this will require replacement of the agitator.
Jul 03, 2009 | Washing Machines
Matag Atlantis MAVT634 will not agitate
Does the motor start and run for agitation with the belt connected?
Jan 29, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine agitates, but does not spin
my amana washing machine does not agitate, but it does spin
Jan 10, 2008 | Washing Machines
Washing Machines Logo
213 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
