Question about Motorola Mobility A630
My Motorola A630 wont charge. No chargers for it work, is there a way i can fix this??
Does anybody know how I can fix this problem?
Posted on Nov 04, 2008
    Brigadier General:
  • 7,752 Answers
Yes the charging port may need to be replace or if the fuse connected to the main-board is faulty then you may need a new mobile but take it to a mobile service center and have it check.
Posted on Mar 25, 2008
Motorola xoom wont charge
this is very common/same problem lots people having with their tablets, but i recently found solution for it.... try the following.
first connect ur charger to the table as you normally would do for charging, then connect the tablet to the computer through the USB wire (make sure charger and usb wire both must connected to the tablet) and it should start charging.... this seem awkward but will 100% work try it and see it urself
Feb 03, 2013 | Motorola Mobility XOOM Android Tablet
Motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Feb 05, 2010 | Motorola Mobility RAZR2 V9m
Razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
Oct 26, 2009 | Motorola Mobility RAZR V3
My motorola Q charger is not charging my battery.
Sir,
It is your PDA battary problem you are suggested to buy new one as by getting charged it cells get weak by the passage of time.
Oct 15, 2009 | Motorola Mobility Moto Q
My motorola hint phone says "unauthorized charger"
u have to turn off ur phone and then put the charger on..thts another way to fix it ..it can be any charger..u have to turn off ur phone then put the charger on
Oct 04, 2009 | Motorola Mobility Hint QA30 Cell Phone
"unable to charge"
I had an old Motorola V3, which used to show me that error. It could result if the charger is not firmly connected to the phone. To diagnose this, try borrowing someone's moto charger. It's also possible that battery contacts could have dust. Try dusting them off so that they're nice and shinny as usual. Finally, try removing the battery for a few minutes, reinsert and charge, leave the phone off when you charge. The phone usually starts working after the regimen. If the problem persists, you'd know which method worked and what failed, so you can press for a warranty. Cheers
Jun 02, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Liquid damage
Yes there is a way but you hv to pay the charges you may contact nearest Service Centre if *********** board change you have to pay 80% of handset cost.
May 20, 2009 | Motorola Mobility A630
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
Motorola v3 car charger
check your cigarette lighter, it may have a blown fuse , check to make sure its not the problem.
Oct 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
A630 won't charge
Don't know how to replace the "fuse" you mentioned but there is an indirect solution to the charging problem. There are a number of cheap Motorola phones that use the same battery. Get one of them from eBay for a few bucks and use them as an "external desktop" battery charger. Then just swap the batteries when needed.
Jun 12, 2008 | Motorola Mobility A630
Motorola Mobility A630 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
