Hard to find parts for Mini PC
I am looking for a cooling fan as in the attached image
  • 42 Answers
CAN YOU GIVE ME ANY NUMBERS OR NAMES OFF OF IT ALSO THE LENGTH, WIDTH,THICKNESS AND HOW MANY WIRES AND I WILL TRY TO HELP.
GOOD DAY
KZ
Posted on Feb 26, 2008
Where is the cooling fan relay on a 2007 linc town car
there is fuse box in engine compartment passenger side, near coolant resolver tank.
See attached picture, 102 (red circle) is 50A cooling fan fuse.
It's not regular ATC or mini fuse.
It's Jcase fuse which look like square plastic box and those are not cheap as ATC or mini.
Aug 10, 2017 | Lincoln Town Car Cars & Trucks
I've got a mini one 2002 cooling fan dose not work unless I turn the a/c on if I don't turn the a/c on it will Overheat
7 Common Repair Problems Mini Cooper Owners Face
www.britishamericanauto.com/car.../7-Common-Repair-Problems-Mini-...
Feb 3, 2014 - This describes the top seven Mini Cooper repair problems owners may ... out the cooling fan and other related parts while the vehicle is apart. ... MiniCoopers aren't the most expensive cars to purchase new, and with .... Your article was a great read and at almost 60K miles , I've been through a few of them.
Mini Cooper cooling fan relay switch located Questions ...
www.fixya.com > ... > Cars & Trucks > Mini
Mini Cooper cars & trucks cooling fan relay switch located questions and answers. Ask your Mini cooling fan relay switch located related question. Get free help from topMini experts. ... I've also seen that problem in some Minis that required the fan motor to be replaced. ... The fan on my cooper s 2002 wont go on any idea.
Radiator Fan won't turn off! - North American Motoring
www.northamericanmotoring.com/...problems.../31220-radiator-fan-wo...
Sep 26, 2004 - Join Date: Aug 2002 ... I've posted a few times here on NAM that I never heard my car's electric fan run after the car was shut off. ... If it does not shut off then, replace that relay (you can find this relay at many ... Took the car in today to get thisproblem fixed. ... There is a recall on aux fan for MINI Cooper.
Dec 26, 2015 | Mini Cars & Trucks
My lap top gets too hot and shuts down
1. blow into the intake vents with canned-air
2. obtain a 'cooling-pad' for a laptop your size
example of a mat-style cooling pad
Xcellon ChillPad Laptop Cooling Mat Gray Black
example of a fan-style cooling pad
Generic Mini Fan USB Cooler Cooling Pad 2 Fans For Laptop Notebook PC...
Oct 28, 2014 | E-Machines Computers & Internet
HP Mini 1000 VT won't turn on, lights flash when plugged in
This is a common issue when the unit has been dropped or jarred really hard. The click is more than likely the hard drive trying to read the disk but can not access information.
With that in mind, try this: Remove all USB, SD, or any cards and attachment from you computer. If you have one at hand, connect an external monitor to the pc. Power on. If you get an image on the external monitor, restart pc and press F8, select "Enabel-low-resolution video" and move forward. If you get a picture after this, your video drivers need updating. BUT......
The clicking sound is a major concern because usually the hard drive is the only hardware part that have moving parts. (other than the optical drive or if you have a solid state hard drive.) If you have a dard drive the same size or close with an operating system on it, replace your hard drive with the GOOD drive and retry. If it boots, you need to replace the hard drive. (and hopefully you have a backup of your data)
Worst case, you may need an authorized HP agent to service your pc.
Good Luck
C2Soluitons
Feb 14, 2012 | HP Mini 1000 VT series PC Notebook
2002 Mini non S cooling fan not working, No power at the relay on terminal 30 but has power at 87
Hello there, i think i can solve your problem , check fuse 3 under the hood it should be a 5 amp if its not the check the closest 5amp to that, check to see if it blown if it is blown then your power steering fan is now working as well as the cooling fan, if that is the cause you will need to replaced the power steering fan as well as the 5 amp fuse, and also in addition you will need to sepate the power steering fan from the cooling fan. Mini parts sells a harness to separte the 2 fan
Mar 18, 2011 | 2002 Mini Cooper
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Aug 14, 2009 | Office Equipment & Supplies
Digital camera works, Pc camera shows blank screen(or black screen)
need to know how to use dual mode and need directions for how to use innovage mini digital camera.
May 05, 2009 | Innovage Mini-Digital Camera
Malfunction detected C-0096
Code Item
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
Feb 10, 2009 | Kyocera Office Equipment & Supplies
Mini fan behind the notebook Compaq nx9010
i took mine apart and it looks like when you use vid out, the yellow thing, that chip will require cooling as does everything on the laptop i think the key board has a frikin' fan anyway, i have not tried this port yet so this is just a hacked guess
Sep 07, 2008 | HP Compaq Business Notebook NX9010
The fan is very noisy
The post begs for the obvious answer: Replace the fan.
Now to be more polite, first you need to identify the failing fan and replace it.
A desktop system can have several fans. Case/processor fan (you can test to see if this is the effected fan by unplugging it for a minute or two from the motherboard (a couple minutes will not hurt the system).
The video card may have a fan on it (Often on the underside if a mini tower) Some video card fans can be easily removed but finding replacement fans can be a challenge. Normally if a video card fan fails, replace the video card.
Most often, the failing fan is in the power supply unit or PSU. If you are handy with electrical components, you can remove the PSU, remove the fan and replace it. If you are not handy electrically, replace the PSU.
Higher end system may have card cage fans to help cool hard drive/expansion cards and others have fans specifically to coll hard drives.
Most manufacturers have spare parts where you can buy parts or you can use google to find specific replacement parts or fan suppliers.
Jul 14, 2008 | Packard Bell Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
