Carrier infinity ac: removed thermostat lines (4) at outside unit to re-route. Reconnected, double and triple checked. No power now to thermostat
  • rdroles Feb 01, 2010
    Since I know I am getting power to the outside unit (checked with voltage meter), it must be the transformer. I will need to call service. Thank you for your help
  • 593 Answers
If you took the wire off outside at the unit you may have tripped a beaker inside the house so check all your breakers. Or the worst case is you may have shorted out the transformer. The transformer will be located inside at the air exchanger unit or the main unit in the house. The transformer takes 110 volts Ac and converts it to 24 volts Ac for the low voltage side, Ie. the Thermostat, and any controls (relays, switches). It may be hard to access or even see depends on model. But check for voltage on the transformer itself.
Posted on Feb 01, 2010
  • Thermo King
    Thermo King Feb 01, 2010
    I was thinking about your problem. If your unit has an electronic thermostat you may take out the batteries or reset the t-stat. It may have sensed the disconnection and gone off line. The thermostat will be the week link in the connections from the transformer to the condenser unit outside.
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Carrier (outside) Coleman Evcon (inside) Air Conditioning question
transformer has just 4 leads. 2 for primary which is your 110 volts and 2 for secondary which is supposed to be 24 volts ac. if you splice the two secondary wires coming out of your transformer, you should be able to get a 24 v ac there.
the box that you are referring to could be a fire controller that in case of fire, it would shut off the fan and the compressor outside.
tnx 4 using fixya,
drcool
Oct 01, 2008 | Heating & Cooling
I have a carrier infinity system. On the thermostat it reads "sens error" where the outdoor temp is normally displayed. The inside unit is running but the outside unit is not. Any suggestions?
A burned or pitted contactor will/can cause a unit to not run. Outside fan. Just thinking out loud. Start with low voltage check at t.stat then check outside low volt. Set t.stat to on. If fan engages at least your transformer is good. Next set calling for cool. Drop t.stat 68-70. If nothing happens go outside and with a screwdriver depress the contactor in. If fan and compressor kicks in change the contactor. If contactor is pulled in check outside fan. Remove the wires from the compressor and see if the fan will run . If it does you have eliminated start components as good. The compressor has to be check. It needs to be ohmed out. Turn off power at disconnect. Pull the cover on the compressor. Check between pins; then pins to ground. Open or infinite is good.Have you checked fuses. Like small 3-5 amp fuses
Jul 03, 2008 | Carrier Heating & Cooling
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Aug 26, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
