Question about HP Photosmart C7280 Printer
C7280 photosmart working with a Mac OS X ver 10.5.8. Recently installed a netgear router and secured the signal. Both the computer and the printer indicate they are connected to the router. When sending a print job wireless the computer initailly looks for the printer and then comes back with a message saying that the "computer is no longer connected to the printer."
  • 1 more comment
  • rhett_russel Feb 01, 2010
    I dont know how to ping the printer and if I did I wouldnt know how to adjust the router settings. can you help with this?
    We're talking about a Mac system I dont have preferences or cant find it
    Just ran well on another mac computer. Appearently problem is on my computer end. Cant locate a printer preferences you mentioned.
  • 542 Answers
Try ping and check whether you are able to ping printer IP. If not check the router settings.
Revert back for more assistance.
Posted on Feb 01, 2010
  • 1 more comment
  • Rajesh Pai
    Rajesh Pai Feb 01, 2010
    Go to printer properties in your system and you can find the IP Address of the printer in port details tab. Now you type ping IP Address in command line and check the output.
  • Rajesh Pai
    Actually i don't know where you will get the printer properties in MAC OS as I am works only on windows platform.
    But i am sure that there is some connectivity issue with your system and printer.
  • Rajesh Pai
    Rajesh Pai Feb 13, 2010
    I don't have any update on the issue? Hope your problem got resolved.
    Revert back for more assistance and give your valuable feedback/rating for the solution provided.
    Thank you for using Fixya.
Tip
Configure PS121 with MAC OS X
Configure NETGEAR PS121 print server with MAC OS 10.4.X and may work for other version of MAC OS X
Please sure that the printer is working in direct connection with the computer.
1. Now connect the printer to the USB port of the printserver and then the ethernet cable from the router to the Printserver ethernet port.
2. Press the diagonistic tool button on the printserver for 10 sec (All the lights will blink amber), you will recieve a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router,If no ip address, powercycle the router, printserver and the printer. Press the diagonistic tool button again.
Open the System Preferences
Click on “Print and Fax” icon
Click on the “+” icon to add a new printer
Click on the “IP Printer” icon
Select “Line Printer Daemon – LPD”
1. In the Address field, enter the IP address of the PS121
2. In the Queue field, enter L1
3. In the Name field, enter L1
4. Select the printer manufacturer from the pull down
5. Select the printer model from the scroll box
6. Click Add
a. Click once on L1 to select it
b. Click on Printer Setup
Click on the “Installable Options” pulldown menu and select “Name & Location”
1. Change Printer Name to IP address of PS121
2. Change Location to: IP_.ip of PS121
3. Click on Apply Changes
The Macintosh is now ready to print.
on Mar 18, 2010 | NetGear PS121 Print Server
My netgear router have strong signal but computer says dont get response from the router
There could be another security settings that are enabled n the router. There is a possibility that the MAC filtering is enabled. You have to disable the MAC filtering.
Apr 06, 2011 | NetGear Computers & Internet
It is printing an extra page in between every page
I got this answer from another website but it worked for me!!
are your computers running windows XP or Vista? because in Vista, if it uses the pre-installed drivers that come with the OS, then it prints blank sheets between the printed sheets. if you install the driver from the CD directly, then it has resolved the issue a lot of times for me.
so to the properties of the printer, and go to the Advanced Tab, and click in New Driver. and in teh wizard, select HP Photosmart 'C7200' and not Photosmart '7200' (considering it is the Photosmart C7280). that should work.
Feb 20, 2010 | HP Photosmart C7280 Printer
Netgear DG824m Disconnecting every few mintes
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 17, 2009 | NetGear DG824M Wireless ADSL Modem Gateway...
Can't get wireless connection to work
Is the wireless card driver installed and working?
Can the wireless card detect your Netgear Router and does it have a strong signal strength?
The Wireless card needs to be configured with the Netgear Router's SSID and encryption settings before it will communicate with the Netgear Router.
Let me know if you have further problems together with error messages.
Jul 31, 2009 | Computers & Internet
How can I connect my wireless laptop to print wirelessly?
run the wireless setup wizard on the printer from the front panel menus of the printer...this would assign an IP address to the printer from the router...then use the s/w cd that came along with the printer and get the drivers and s/w installed on your computer....if you want a wireless connection it would give you approprite options
Jun 21, 2009 | HP Photosmart C7280 Printer
Days to set up Wireless laptop to HP Photosmart C7280 All-in-one
try this Update the firmware in the wireless router
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859761879&packedargs=sku%3DWRT54GS&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=6187961879B01&displaypage=download
Broadcast SSID(if changing security, you may want to change this)
Use WPA security(some devices won't work unless WPA security)
Mixed b and g mode
use channels 1, 6 or 11. Most devices work better on these channels
Save and log out restart everything, Routers and computers. Now connect.
Drivers can be found here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3204785&lc=en&cc=us&dlc=en&submit.y=9&submit.x=10&lang=en&cc=us
Download them. When you install them, choose network.
You do have one of these?
HP Wireless Printing Upgrade Kit
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00783236&lc=en&cc=us&lang=en&rule=5307&dlc=en&product=3204785
Jan 09, 2009 | HP Photosmart C7280 Printer
Will not print
dirver conflict, completely remove from OS, take off network and see if HP works independently well. reset on network and share again.
Jun 22, 2008 | HP Photosmart C7280 Printer
HP Photosmart C7280 Printer Logo
156 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
