Question about Philips PR1903C 19" TV
Forgot tv password
I forgot the password to my phillips tv channel blocking. I cannot view six channels. How do reset the password or take it off?
  • ashley_ross Feb 01, 2010
    Model: PR1903C121
    Make: Phillips Magnavox
  • 8,197 Answers
May I get the make and model # of the tv to help you.
Posted on Feb 01, 2010
  • Jyackle5
    Jyackle5 Feb 01, 2010
    Press the MENU button
    on the
    remote to display the onscreen
    menu.
    Press the CURSOR UP
    s or
    CURSOR DOWN
    t buttons until
    the words SmartLock are highlighted.
    Press the CURSOR RIGHT
    button
    to display the SmartLock
    Access Code screen.
    Using the NUMBERED buttons,
    enter 0, 7, 1, 1. “XXXX”
    appears on the Access Code screen
    as you press the numbered buttons.
    “INCORRECT CODE”
    will
    appear on the screen, and you will
    need to enter 0, 7, 1, 1 again.
    Press the CURSOR DOWN
    t
    button
    until the words CHANGE
    CODE
    are highlighted.
    button
    to change your personal
    Access Code.
    “Next enter a “new” 4 digit
    code using the NUMBERED
    buttons.
    The screen will then ask
    you to confirm the code you just
    entered. Enter your new code
    again. “XXXX”
    will appear when
    you enter your new code.
    Press the STATUS/EXIT button
    to save the new code in the
    TV's memory.
    Or you can get the manual on link below and on page 21 tells you how.
    http://www.retrevo.com/d/ds/progress?doc...
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
How do i unlock lost or forgen password.?v hold
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
May 24, 2013 | RCA E13320 13" TV
How to reset a password
Set up blocking schemes to block specific channels, ratings, and external viewing sources.
A password is required to gain access to this menu.
Setting up Your Password
For USA
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
Movie Rating
TV Rating-Children
TV Rating-General
Downloadable Rating
Input Block
For Canada
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
TV Rating-English
TV Rating-French
Downloadable Rating
Input Block
Close
Enter Password
Select LOCK.
1MENU
ENTER
Input the password.
2 Enter the password as requested.
The TV is set up with the initial password
"0-0-0-0".
Hope this helps
John
Sep 17, 2011 | LG 42LG50 42 in. LCD HDTV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips PR1903C 19" TV Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
