Question about Emerson EWR20V4 DVD Recorder/VCR
Ewr20v5 can't get it to show set up menu
I am connecting this to a fisher tv, and on our old vcr it had a channel switch on the back,which we toggle to channel 3, this ewr20v5 does not have that, but i have gone through all the channels, and still can't display menu to appear
I am not sure what it is, we are using the yellow and red cords now, as this is how we set up our current vcr, Can I send you the back of the tv, would that help/??
Thanks
Posted on Feb 19, 2008
Zmomusa-Well for starters i'm guessing that you have an RF out to tv (where you hook up a coax cable).most units work on channel 3or 4,if you don't have RF out try going into tv through the video input (red ,white and yellow plugs) this may be easier and you will get better picture.If your not sure let me know I can help you. cooltekFeb18/08
Posted on Feb 18, 2008
How do I set the clock on a fisher fvh-7600 vcr I do not have a owners manual
Also having no manual for a Fisher FVH-7600, I eventually guessed how to set the clock after finding a remote control (Fisher RVR-7600) that works with it.
With the TV and VCR connected and powered on, the TV set to channel 3, and the remote's FUNCTION switch and VCR/TV button both set to VCR, I see a blank blue TV screen.
Then I press the PROG. button on the remote, and a menu with instructions appears on the TV screen. CLOCK SETTING is item 1 on that menu.
Sep 23, 2014 | Televison & Video
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
What buttons do i press to add/delete channels on emerson tv model# EWC1304? I cannot seem to get pass channel 2. I have no remote.
I have the same problem, my tv will not allow me to change channels but will only let me add/delete the channel the tv is currently on
Oct 11, 2011 | Emerson EWC1304 13 in. TV/VCR Combo
Only the lower channels work
Sounds like somehow the TV got switched from Cable to Antenna.
If there is a Menu look for a way to switch it back.
If it is REALLY old there may be a Cable/Antenna toggle switch on the back of the TV. If so, put it in the Cable position.
Jul 02, 2010 | Toshiba MV19KI 19 in. Combo
I've had a number of vcrs and vcr/dvd players over the years. But for some reason, I cannot set up this machine. I set up all of the cables exactly like I always have and the way that is instructed, but I...
These days the video input channel depends on the TV and any other equipment in the sequence. I've seen component video come in as Line, Channel 3/4 (with a switch on the video device), Aux1, Ex1, AV1, Channel 60 (I think that may be specific to satellite dish receivers). If the remote has an input button, try that (alternatively, look in the menu for source options). One thing to try: press the PSCAN button on the DVD remote (to toggle off the Progressive scan).
On some TVs the channel for the video is reached by going down from Channel 2 (this works when no channels are programmed into memory and the intervening channels are skipped).
What TV are you connecting to the DVD/VCR player? (If it is an older TV and any external device was connected to either channel 3 or 4, check that the TV works with any input device. I had a 19 year old TV (coax in only) that was damaged and no external device worked.)
I wish that I could be of more help.
Apr 26, 2010 | RCA DRC8335
I have an old daytron tv, with no remote, how do i get it on channel 3
always toggle through the tv/video button to make sure your on the correct source. usually the menu button is pressed, then the up/down and left/right button navigate the menus.
make sure your vcr or satellite receiver is on and set to use channel 3
press the menu button on the tv untill you get to channel settings, look for auto channel setup or search. If the signal is coming through on ch3 and the cable is correctly installed from the source to the tv, this will find the broadcasting station and lock onto it.
If you dont have a menu button on the tv , it could be hidden behind a small door,
if still no menu button, you will have to find a replacement remote to set the channels.
Apr 03, 2010 | Televison & Video
Got no instructions
1-The TV needs to be on channel 3.
2-On VCR remote set VHS/TV switch to VHS. (click it a couple of times until VCR channel shows on screen)
Dec 25, 2008 | Televison & Video
Hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Mar 04, 2008 | LG 42LC2D 42 in. LCD HDTV
"Line In" mode (on both TV & VCR) -- (Please help) "Get (them) Back to "Normal"!"
it sounds like you need to get a universal remote that has an av setting on it usuall this is 0 or an av button this shoud toggle between these modes sorry couldnt be any more help
Oct 31, 2007 | Televison & Video
Hitachi F361 VCR Digital Auto Tracking (not 631!)
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Oct 31, 2007 | Hitachi VTFX631A VCR
Emerson EWR20V4 DVD Recorder/VCR Logo
49 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
