Question about Whirlpool LHW0050PQ Front Load Washer
What is code F21
Not sure what code F21 is and when I turned the washer back on it just hums like the motor is bad!
F21 is:
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Feb 06, 2010
Will not spin or drains shows F21
The F21 error on a Whirlpool Duet washer means the unit was draining slowly. This can be caused by a blocked outlet hose (kinked hose, for example), excessive suds from using non-HE detergent or too much detergent, blockages in the drain pump filter (coin catcher), or a problem with the pump.
You should be able to clear the error by pressing Pause/Cancel twice. Check your outlet hose. Then unplug the washer. Have a bucket handy to catch the water when you access the pump. Remove the toe panel from the bottom of the washer. There are three screws to remove; then you need to lift the panel slightly and pull it forward.Check the filter for foreign objects.
Test the washer by selecting a cycle and running it with no clothing or detergent. If the unit still fails, then the pump, pump motor or the pressure switch is bad. However, you should also check the wiring to the unit.
I hope this helps. Please add a comment with the model of your washer for specific directions and parts information.
Dec 22, 2014 | Whirlpool duet Washing Machines
Washer code is f21
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Sep 20, 2011 | Kenmore HE2 Plus Front Load Washer
F21 what can I do? Please please
Hi
F21 error in your Bosch washer relates to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Bosch Logixx WAS2446 Front Load Washer
I have a f21 code on my washer. what do i do?
Hi
Daniel
Feb 15, 2011 | Maytag EPIC MFW9700S Front Load Washer
What does F21 mean on the digital screen?
Hi
Error F21 means F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
Keeps on coding F21 - we have adjusted the hose several times but still seems to be giving us problems
Hi
Daniel
Jan 01, 2011 | Kenmore HE2 Plus Front Load Washer
What is an F21 flashing? My washer will not turn off or anything. It is humming and flashing F21. Thanks
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
Thank you !!
Aug 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I AM GETTING A F21 CODE WHICH MEANS UNABLE TO
What you should do is get a flashlight, remove the hose from the pump and look into the suction port on the pump. Check the blades on the pump impeller. Make sure that no blades are broken or missing and that the impeller rotates freely. If any blades are missing or broken or if you cannot get the impeller to turn freely, then the pump will need to be replaced. Hope this helped and best wishes.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
212 people viewed this question
Dan Webster
Dan Webster
Sal De
