Question about Maytag MDE2706 Electric Dryer
Looking for a manual for maytag MDE2706AYW
Looking for a manual on how to remove the panels to get inside this model, it is not putting out any heat, any other tips on where to check would be helpful also, thanks
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: WONT HEAT
This is a simple dryer to diagnose.2d23ddb.jpg The limits and heater or mounted in the lower left corner of the rear bulkhead. Unplug the dryer and remove the front panel.1d97909.jpg Remove the 2 screws holding the element and get it out. (only two wires to take loose) Get it out9f0a336.jpg and check it for continuity between them two connections or simply examine the heater for breaks. If all of that is ok The cycling thermostat might be whack. If all of that is good and you have 240 volts at the receptacle then the timer may have a burnt contact inside 2261b68.jpg
Posted on May 20, 2010
  • 6 Answers
SOURCE: maytag model MDE7057AYW 5600 Watts dryer runs ,but
Most electric dryers run on 110 volts, but heat on 220 volts. Unit needs to be wired to 208 to 240 volt, 30 amp circuit to Run and HEAT properly. Motor, interior light and controls run on 110 volts, neutral (white wire) and one hot wire, usually black. The heater works on both 110 volt hot wires, usually one red and one black wire. Unit can be hooked up to run and heat on 110 volts but will allways take two or three times as long as a 220 volt setup. It is producing half or a little less of its 5600 watt rating. It takes three things to efficiently dry clothes: heat, air flow and tumbling action. Remove any one and the unit runs much less efficiently. If you need a dryer to run on 120 volts, buy one that says 110 - 120 volt operation only, but it will still take up to two hours or so to dry a load. Brent
Posted on Mar 12, 2009
  • 67 Answers
SOURCE: need to remove the shell off of a Maytag
From the front all is accessable and plenty of room to repair. Make sure you clean out the dryer before putting it back together and check the slide plates and rear rollers.
Posted on Aug 15, 2009
Message "suds" appeared on my Magtag laundry machine
There is a panel at the bottom front of your machine. Remove the 3 - 4 screws at the bottom of the panel. Inside the panel you will find Service Codes and other useful info. It's a good place to keep them so my advice is to put them back when done with them. It is indicating "suds" because you are either using too much detergent, wrong kind of detergent (make sure it's high-efficiency detergent) or you need to clean the catch basket on the drain pump.
The owner's manual can be downloaded here:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/user-manuals/manual-downloads/Model-MAH2400AWW/3048/0153200?modelNumber=MAH2400AWW&diagramPageId=&documentId=
Hope this helps.
Dec 24, 2012 | Maytag Washing Machines
WONT HEAT
May 20, 2010 | Maytag MDE2706 Electric Dryer
I have a Maytag gas dryer model # MDG7657BWQ...how do I open the cabinet? I cannot release the clips to pop the top - I think this is the first step...please advise Heat comes on and then goes off..I...
remove the door first, then remove the stops opposite of the door then give the panel a twist at the left and the right on the vertical skinny parts of the front panel lean the panel forward and pull up it will come off. the clips should not come off pay careful attention to how it comes aprt so that you can put it back together. the coils are inside to the right, check the ignitor operation as well to get the thing to work you will need to trick the dryer by putting the door back on temporarily with no screws and door closed.
Jan 06, 2010 | Maytag Dryers
Need to remove the shell off of a Maytag MDE2706AYW dryer to replace the heating element, but can't figure out how the thing comes apart....
Aug 15, 2009 | Maytag Dryers
Maytag dishwasher Model MDB9150AWQ won't unlock
try this keystroke..."high temp wash" "heated dry" "high temp wash" "heated dry"
Apr 17, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Heating problem
Unplug the dryer.
Take a putty knife and insert it at the top of the front panel just below the lid and push the 2 clips in.They are about 2 inches in from the right and left sides.
Raise the top lid towards the rear of the machine.
Remove 2 screws on the inside top corners of the front panel. Remove the front panel.
Remove the belt. Remove the drum.
The heater will be on your bottom left.
Apr 12, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryer belt slack
Start from the motor threaded shaft. Then pull out the Idler pulley so that the back of the belt will lying on the Idler pulley in upright position. that is all.
Mar 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
DRYER LINT
you can purchase a brush for the dryer, you can reach down further with it.
Nov 19, 2008 | Dryers
My maytag neptune washer model #MAH8700AWW door is locked and wont release. Is there some manual release?
there is no "red string" on this specific model. Its really irritating that everyone is saying this when clearly no one can find a red string. Stop giving this advice. From what i can tell so far the release lever is inside the machine and to get to it you have to remove the front panel. My problem now is i cant get the top electronic panel off to get the front panel off... this machine is like a giant chinese handcuff!! I will never buy a maytag ever again!!
Jun 22, 2008 | Maytag Washing Machines
DRYER WON'T HEAT.
ok facing the drier front open thee door and remove the bolts around the door panel there are four of them two on each side then grasp the front about 3 inches down on either side to disengage the side retain clips tilt the panel back toward you and lift it up to disengage the bottom clips remove the front panel and if you need to lift the top remove the screws on the hooks on either side at the top and take the hooks off then you can lift the top that should give you plenty of access to do what you need to do
Jan 20, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDE2706 Electric Dryer Logo
427 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
