Question about RCA HD52W59 HDTV Projection Television
HD52W59 CRT Arcing
I have HD52W59 that stop working while we were watching it. When we turned it back on I saw an arc coming from the front of the TV. I removed the front cover and cleaned a lot of dust from the circuit boards. I plugged the TV back in and found the arcing coming from the CRT on the right side facing the TV. My guess is that this CRT is out. If so does anyone know the pat number? And where is a good place to fide one? If this is not the problem then what do you think it is? Thanks for your help.
  • ws5b Feb 20, 2008
    Genius:
  • 1,030 Answers
Blue Crt arching... on the board or on crt? most likely if it is arching you are right in suspecting the tube. These tube are around 240 dollars per tube and then i would sugest replaceing crt board. I work on alot of these at the shop. bottom line if there not under warenty then really not worth fixing. these set cost about 800 new it would cost around 500 to fix. crt replacement of these set is a very involved process. I think almost ever screw in the set has to come out and then after you get it all back together. theres the alignement issues.. im not saying dont do it just if you like a challenge go for it.
Posted on Feb 18, 2008
When I turn the tv on, it sounds like static electricity coming from the back.
Check its final anode connection for arcing. You have to replace the final anode rubber boot, if arcing is here. Seek tech support. This is a dangerous work, for an un-experienced one.
Jun 22, 2012 | JVC Televison & Video
Hd52w59 wont turn on
If you can get at it this set has a high voltage splitter up front (remove entire front grill beneath the screen and the inspection plate behind that) that also fails---it is usually tan in color and has a red HV lead coming from flyback to it---three wires there go to the picture tubes--just remove the one or two screws that secure it and look at the bottom for any burn marks or signs it has been arcing.
May 01, 2012 | RCA HD52W59 HDTV Projection Television
It pops for awhile, then stops for about a week then it will go out completely. Place the tv in a corner for about a week turned off and then turn it back on, it will work again for awhile.
This could be caused by the high voltage transformer arcing or one of the anode leads arcing at the CRT cap. If you can monitor the back of the set open while in a dark room setting may show where the arcing is occuring
I hope this helps,
Skyassoc
Dec 08, 2010 | Hitachi 51F500 51" Rear Projection...
A shorting noise is coming from inside the tv box - this happens when i switch on the tv but later , after 5 minutes or so stops - the noise , in bursts, asif two wires are touching.
Hello
There is a high tension arcing takes place inside your tv. It may be related to Line Output Transformer [LOT], and neighbouring parts. You can locate this by placing the tv in an absolute dark room, switch it on, and notice its inside through the back ventillations. you may see bluish arcing takes place, and an ozone smell will come too. Never switch on the tv till this fult is retified. Some other parts alo may get damaged.
Contact a sevice personal and get it repaired as soon as possible.
Oct 19, 2010 | Sansui 32" TV
Tv acts like its going to turn on, but then shuts back off
sounds like high volt arcing. i would get it checked out pronto could do much more damage if it is hv arcing.
Dec 13, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
RCA HD52W59 HDTV arcing internal high voltage tower help
http://www.riddledtv.com/repair/RCA.html
http://serviceman.site88.net/index_files/Projection.htm
try these sites see if they help u
need to know chassi
Oct 03, 2008 | RCA HD52W59 HDTV Projection Television
Hitachi 51F510
The loud "pop" sounds like high voltage arcing coming from one of the CRT's.....you may have to pull each CRT out and put silicon sealant on the anode connectors to prevent the arcing.(one of the CRT's may be arcing internally also and the only cure is to replace that CRT) If you let the arcing continue,it will short out the horizontal output transistor sooner or later.......
Mar 28, 2008 | Hitachi 51F510 51" Rear Projection...
Mitsubishi VS-50707
Check the CRT socket of the tube that is arching. Could be a solder connection or shorted CRT. If you need further assistance let me know.
Feb 03, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
160 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
