Question about Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
Lens error message, will not retract - Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
  • 3 Answers
Turn it on then wiggle the lens very gently to the right, then turn the camera off, repeat both until it does it on its on.
Posted on Feb 01, 2010
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
Lens won't retract
Lens probably does not extend or retract because of debris or a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 07, 2010 | Kodak Easyshare M753 Digital Camera
Lens error
Hi.
Check the articles below and follow troubleshooting in case of lens error:
Lens Error.
Regards.
Apr 09, 2010 | Nikon Coolpix S210 Digital Camera
Lens error message
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Jul 18, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Jul 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
Apr 06, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Bonnie
I was getting the Lens Error message on my A730, even though my lens seemed to be working fine. I'd had the camera in my pocket, and apparently it tried to open but jammed. But it seemed to be OK except for the cursed Lens Error message when I'd power it on. The way I found to fix it is press and hold the "func/OK" button on the back, then turn the camera on. Now it's working again. Note that this may not work for you if your lens is actually screwed up. Mine wasn't.
Dec 12, 2007 | Cameras
Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
128 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
