Question about Kenmore 24032\24036 Top Load Washer
What is usually wrong when water will not fill in a new Kenmore elite 800 washer? The spin cycle works but will not fill with water. Washer is only 3 months old.
  • 105 Answers
Best off to call Sears Service and Repair dept. as this will be covered under the manufactures one year warranty.
Posted on Feb 01, 2010
  • 714 Answers
There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way? If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Kenmore elite oasis washer will fill with water and skip the wash cycle. It will spin and empty then turn off. we have seen the code UL what can be done to fix this?
UL=Ultra Level of water?
usually its just foam in sensor tube,as prior using too much or wrong type of detergent(for hand wash,or else). Do few cycles with just and only water,or open machine and blow tubes to level "sensor".
Jan 24, 2015 | Kenmore Washing Machines
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
you have a clogged water pump....its simple to unclog but thats whats wrong a clogged water pump
Jan 29, 2009 | Washing Machines
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Spin cycle problem
Which machine exactly do you have ?
Aug 31, 2007 | Kenmore Elite 45986 Front Load Washer
Washer only works on spin cycle
Sounds like u need a new control panel
Mar 18, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
140 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
