Question about Kenmore Refrigerators
Drain pan under refrgerator overflows
Drain pan under refrigerator overflows
  • 105 Answers
Overflows or is it cracked. Best off to call a reliable service company such as Sears.
Posted on Feb 01, 2010
Why does drain pan overflow? How is water in pan suppose to go away before overflowing?
Are you sure it is the drain pan overflowing? If water is appearing on the floor every few days, it may not be getting to the drain pan (evaporator tray), due to a blocked drain channel. The evaporator tray will normally cope with the daily amount of de iced water of a frost free fridge/freezer.
Mar 07, 2015 | Refrigerators
DRAIN PAN FULL OF WATER AND OVERFLOWING ONTO FLOOR
What kind of unit do you have? Its possible depending on the manufacture that a water line is the cause as it drips water into the pan causes the overflowing of the drain pan. Look for cracks in all the water line under the unit and you may have to remove the back and the water valve to see it. Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Stop water overflowing in frIDGE FREEZWE
-You mean from the bottom of the fridge...? If so, the drain pan or the pan that catch the water must be off from the line. Take a look. If it doesn't sit under the drain tube, fix it (move to under the drain tube). So you won't see water under fridge any more.
-But if it's from the Inside. The drain hole is plug. Check and clean it.
Good Luck
Mai Lor
Dec 04, 2014 | Refrigerators
Drain Pan overflowing and water is leaking in refrigerator I can see drip pan overflowing but I do not know how to get to it
remove the back panel inside the freezer,then defrost the pan,then take a length of stiff wire and clear out the drain line from there down to the pan in the lower area near the compressor,as theres probably lime,mold growth build up in the drain line plugging the hose restricting draining of defrost water
Mar 03, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Have side by side 10 years leaking water on floor in front of refrigerator there is no water connected to refrigerator, cant find an overflow pan under neath...
clogged drain causing the water that cant reach the drain pan underneath to leak on the floor. Unplug fridge and open doors for 24 to melt ice likely clogging up drain. If that doesnt fix, you'll need to call refrigerator repair service
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Drain pan over flowing
The rubber seal on the water filter is bad . Replace the filter in the bottom kick plate . When the filter goes bad , water will drip into the drain pan , causing it to overflow .
May 12, 2010 | Kenmore 57029 Side by Side Refrigerator
Drain pan of refrigerator is filling up and overflowing onto the floor. This never happened before.
Maybe it is because of increased humidity inside the fridge. This could be caused by the door not being properly closed or leaking.
May 31, 2009 | Maytag MSD2656G Side by Side Refrigerator
Drain pan keeps overflowing
sounds like the drain be be getting clogged. you will have to find the tube, remove mounting screws and bracket and blow out with compressor or pipe cleaner
Apr 15, 2009 | GALAXY Microsystems 25.4 cu. ft....
Water builds up and overflows on the bottom of our fridge
get into the evap. section of the unit [cooling coil] , there is a pan under it with a drain in the center , its frozen or plugged , defrost it and use a firm wire or similar to snake it out , when you get it draining in the pan again pour a cup of bleach in the evap. pan to clear mildew or whatever is in the line.
Phil
Apr 14, 2009 | Whirlpool EL7ATRRKS Refrigerator
Whirlpool side by side defrost drain pan overflowing
Maybe your machine has a leaky door, letting moist air inside. Make sure your compressor area is lint free. The heat from the compressor is supposed to evaporate that water. Make sure the pan is exactly in the right place, level, not cracked.
Feb 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
277 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
