Question about Hunter Fan Company 5/1/1 Programmable Thermostat
My 44860 keeps freezing up, meaning that every few days it just locks up and I have to pull out the batteries and reseat them to get it to come back on
Same problem once it gets to the set temperature the burner turns off and the fan stays on and blows cold air.
Posted on Feb 02, 2010
Directions for installing #44860 deadbolt
Measure 60mm back from the edge of the door, drill a 32mm hole.
Fit the cylinder, check for length of tailbar (you may have to shorten)
Fit lock body, lock strike onto lock, close the door, and mark where the striker needs to be fitted.Rebate strike into door frame.
Apr 17, 2014 | Ultra Hardware Ultra 44860 Jimmyproof Lock...
Bep problems of the computer
You mean you can't start your computer and it "beeps"? If is that so, then it means you've received a BIOS beep code which means you have problems with your RAM, video card or the motherboard or its configuration (it depends if it is a laptop or a desktop computer).
You should reseat (take out and put back) all the components and reset the BIOS (remove the CMOS battery, keep it out for a few minutes and replace it). Then try again. If the problem isn't solved just tell and we'll try to understand what is wrong.
Jun 13, 2013 | Computers & Internet
I have a Samsung SGH 1897 that keeps freezing/locks up. 2-3 times a day I have to pull the battery out to get it to reboot. Any idea how I can resolve this?
Your phones software has corrupted. Try to hard reset your phone. This option is located in the phone settings. If this does not work then take it to a service centre and ask them to re-install its software. After that your phone will be okay.
P.S: All your phone data will be lost after hard resetting or re-installing. So back up your data first.
Aug 18, 2011 | Cell Phones
Well my phone died so i plugged it in to charge but it keeps freezing at the chatge screen and wont turn on! i dont know what to do! please help
pull the battery out and put in freezer over night than put back in phone as the phone is in lock out mode and battery might be bad but if you freeze it it will come back to life for a bit
Apr 05, 2011 | Cell Phones
Hunter 44860 Thermostat - continually resets clock to 1am
My Hunter 44860 is doing this also. It started on Nov. 1, 2009. It also displays the day of the week as "SUNDAYAY" when it hangs. I believe this is a firmware problem with older stock. Unfortunately I bought it from Lowes this fall and lost the receipt. I am going to try to return it to Hunter Fan Co for an exchange.
Nov 09, 2009 | Heating & Cooling
My phone freezes
Keep in mind your cell phone is like a tiny computer, so it needs to power cycled or in other words, just turn of off and back on at least once a day. If you don't do this your phone will run slowly, act strange or get really low signal strength. Often times a phone will just crash- like what yours is doing I this is not done.
Do pull out your battery, though and find your liquid damage indicator strip. If it is red this means your phone has been exposed to moisture. If white then everything is fine.
May 13, 2009 | LG VOYAGER VX10000 Cellular Phone
Keypad freeze
Did the key pad froze before you took the battery off? If so, it mean the keypad is damaged. If you have insurance, you may call customer service and have it replaced for a new one.
If it frozed after you shoot it off, you might call customer service from another phone and they might help you to unlock your phone.
Artgirl
Jul 17, 2008 | Samsung SGH-D900 Cellular Phone
Wet phone
for one you do not want to keep trying to power up a wet phone.pull the battery and let it sit over the heat vent for a few days.by trying to keep powering up you can actually short electronics inside.another thing you can do is use a blow dryer.depending on how much water is inside,i have actually brought a few back to life..if you can find someone that has enough mechanical background 2 open it up there is some great electronic cleaner called missy that will disapate the water.but leave it on the vent for a few days with the battery pulled and you want to get it as open as you can to get the water out
Mar 24, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Phone freezes at random times, pull battery to restart
your old phone may have just needed a new sim card, as for if your new is not working use the warranty and send it back and replace it.
Sep 27, 2006 | Motorola Mobility RAZR V3
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
314 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
