Question about Maytag Neptune FAV6800AW Top Load Washer
Neptune FAV6800AWW Just stops agitating or spinning
It seems there is a slight leak (I think because of the top seal worn out)at the bottom which caused the clutch to seize up and preventing the unit from spinning CCW. I removed the clutch and was able to clean and lubricate it. I guess I had the bolt on too tight and the unit refused to turn. After loosening it could turn fine, however...
Now the unit refuses to agitate or spin.I have conducted all tests on the unit I could find. Motor test, spin test, drain test, quick cycle test, etc, but it returns no codes.
On normal washes it will fill, start to agitate then quit. Also the counter stops counting down. (did this before the clutch clean-up).
Before the unit would just stop counting down and would just keep agitating on and off.
Spill test: Start to spin normally then just stops. Feeling, observing, and listening to the belt underneath, the motor is not having trouble turning the drum. It just stops and refuses to turn anymore. Spin test will finish.
Motor Test: Motor spins the tub at 50 RPM just as the manual says it should (though with a bit of ticking sound).
SN is 10008874EL
Any more ideas?
  • 1 more comment
  • Trent Creekmore Feb 01, 2010
    Thanks!
    Are the control boards expensive?
    Is that the Main Controller Board, or the Motor Controller board where it is located?
  • Trent Creekmore Feb 03, 2010
    "Was the One-Way Roller Clutches upper bearing ring and Clutch Pulley mounted One-Way Roller Clutches bearing severely rusted up? Could you turn the wash tub CCW by hand with very little resistance before you started into the Clutch Maintenance?"
    Yes it was rusted and the tub would not turn CCW at all.
    "Ok so that was the original problem correct?"
    That was one of them. I thought it was related to the tub not being able to spin. Now I see it is two different problems.
    " Before that I would try reseating JP4 on the Motor Control Board. The PWM input signal from the Control Board comes into the Motor Controller on that plug. This digital signal controls Motor Speed and direction via the Motor Controller. This may buy you nothing but no cost involved also check for corrosion on the plug and mating Motor Control Board connector"
    that area was fine and no signs of corrosion anywhere.
    Thanks for the further help. I guess I am off to fund a cheap controller board, if it exists.
  • 526 Answers
“”It seems there is a slight leak (I think because of the top seal worn out)at the bottom which caused the clutch to seize up and preventing the unit from spinning CCW.”” Yep I’m sure you may have a slight tub seal leak. Was the One-Way Roller Clutches upper bearing ring and Clutch Pulley mounted One-Way Roller Clutches bearing severely rusted up? Could you turn the wash tub CCW by hand with very little resistance before you started into the Clutch Maintenance?
“”I removed the clutch and was able to clean and lubricate it. I guess I had the bolt on too tight and the unit refused to turn.”” I believe you did not have the upper One-Way Roller Clutches bearing ring seated in the Outer Tub correctly when you reassembled. It is a tricky fitment/reassembly process. If the ticking sound if coming from the area of the clutch pulley that tells me it still not quite seated properly.
I recommend to lay the Washer completely on its back with a 4x4 placed just ahead of the drain hose exit, the fitment process is a bit tricky. You have to get that upper One-Way Roller Clutches bearing ring seat properly in the base of the tub. I believe the ticking sound is coming from the Clutch Pulley assembly is that correct. When you opened up the Clutch pulley was the clutch spring OK?
“”Now the unit refuses to agitate or spin.I have conducted all tests on the unit I could find. Motor test, spin test, drain test, quick cycle test, etc, but it returns no codes. On normal washes it will fill, start to agitate then quit. Also the counter stops counting down. (did this before the clutch clean-up). “” Ok so that was the original problem correct?
If so I agree with the fist forum member’s solution. The Control Board is expensive unless you buy like I do e-bay used with Membrane Console. I feel you have lost PWM signaling from the Control Board to the Motor Controller input. The Main Control Board is in the Console. Can’t rule out a Motor Controller for sure but I lean toward the Main Control Board also P/N 25001217 item 23 for all series. Before that I would try reseating JP4 on the Motor Control Board. The PWM input signal from the Control Board comes into the Motor Controller on that plug. This digital signal controls Motor Speed and direction via the Motor Controller. This may buy you nothing but no cost involved also check for corrosion on the plug and mating Motor Control Board connector. The Service manual will take you through removing the Motor Controller it’s a tight work area as the clutch. Remove the AC power cord to the washer before these checks.
AZ Control Board 25001217
JP 4 on the Motor Controller;
Good luck......Rich
Posted on Feb 01, 2010
  • Maytag Master
  • 12,061 Answers
This is indicative of a Microprocessor fault...
Testimonial: "I was thinking it could have been to, but I have no experience with eletronic washers and the manual does cannot cover all possible problems. "
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Drawer wont slide and dishwasher does not work
please provide the model number of the dishwasher so that I can identify the type of lid seal it is using. Usually the lid seal actuator motors are stuck and prevent drawer from opening. You could force it open with a slight tug. Otherwise turn the mains power off and on and see if it makes any difference. Need to check the lid seals for damage otherwise it may leak in future and cause flood switch to trip.
Dec 07, 2012 | Fisher and Paykel Dishwashers
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Possibility of a cracked block. how can i be sure/
Vehicles: Any with the above symptoms
A cracked cylinder block will cause either:
(a) motor oil contamination of engine coolant
(b) coolant contamination of motor oil
(c) white exhaust smoke, due to coolant seeping into one or more cylinders.
(d) more than one of the above
(e) all of the above
Oil infiltrating into coolant is easy to see - drain some coolant out through the pepcock at the bottom of the radiator, and place it into a styrofoam coffee cup. Oil droplets floating on top of the green (or orange) coolant are easily seen. Or visualize oil by looking into the top of the radiator through the radiator cap.
Coolant infiltrating into and mixing with motor oil will permanently damage the engine (seizing it up through loss of lubrication), and must be prevented.
A leak from above the front suspension is, as physicians like to put it, "nonspecific", with the most likely cause a water pump seal or hose/hose connection.
A leak from near the fire wall will usually be a heater core hose, or hose connection.
A coolant leak on the same side of the engine as the water pump is a leaking water pump or water pump seal until proven otherwise.
To rule out everythng else, here's the 1999 Honda CR-V Troubleshooting Guide for Coolant Loss/Coolant Leaking:
Priority Action Part Type Cause
1 Inspect Water Pump - Worn, Cracked or Leaking Water Pump, or Water Pump gasket.
2 Inspect Head Gasket - Leaking Head Gasket.
3 Inspect Radiator - Leaking Radiator Hose(s).
4 Inspect Radiator Cap - Worn or Damaged Radiator Cap.
5 Inspect Radiator Hose - Ruptured, Cracked or Leaking Radiator Hose.
6 Inspect Freeze Plug - Leaking Freeze Plug(s).
7 Inspect Intake Manifold Gasket - Leaking, Worn, or Damaged Intake Manifold Gasket.
8 Inspect Water Outlet - Cracked, Leaking or Damaged Water Outlet.
9 Inspect Heater Control Valve - Leaking or Faulty Heater Control Valve.
10 Inspect Radiator Drain Pepcock - Loose, Damaged, or Faulty Radiator Drain Pepcock, or Pepcock O-ring.
11 Inspect Engine (DOMESTIC ONLY) - Cracked Cylinder Block Leaking Coolant into at least one Cylinder, causing white exhaust smoke.
Dec 03, 2011 | 1999 Honda CR-V
Leaking at bottom of washer after it spins out not alot of water but a pain in the ****, how do you get in to the back of the washer?
The FAV6800A and FAV9800A only have access thru the front panel and washer top once released fromt the base......no rear or side access. See Pick of Outer Tub removed for Tub Seal and bearing replacement.
Google ""16022808.pdf"" to find the Service Manual.
Page 33 will show ou how to release the top cover and page 41 for front cover removal.
If you have wash water leaking down on the Clutch Pulley I feel you have a Tub Seal leak. The issues could be related to the drain hose/drain pump or cracked outer tub.
I don't troubleshoot on this forum to difficult to carry on thread. Google ""Neptune TL Washer FAV6800AWW"" or ""FAV6800A/FAV9800A Outer Tub bearing replacement"". Two DIY forums I frequent that I feel are true DIY forums.
Sep 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Leaks water underneath - i think it only does it during the cycles that spin extremly fast to wring the water out
FAV6800A or FAV9800A correct?
If so you need to remove the front cover and try to determine if the water is coming down the Spinner Support shaft or if there is a leak in the drain line system.
I suspect with limitted info this could be a tub seal leak. with water collectig on the Clutch Pulley. Possible Tub Seal issue a big job but can be done by a basic DIY'er. I have helped others on this site replace the tub seal and Outer Tub Bearings.
If you want to DIY the fix we need to troubleshoot further and this is not the forum for that.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" post your problem as a new issue not in the sticky and I will try to help.
Jan 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Bike is at 63000km and has now gone in for 3rd clutch. Am not a hard/sand rider, do not wheelie, etc, etc Bought the bike second hand and first clutch was replaced at 15000 under warrantee. Now at 63000...
If all your clutch problems have been caused by oil leaks, make sure the mechanic working on the bike this time installs all new seals in the transmission and the crankshaft seal on the rear of the engine. Since the input shaft is hollow, you must replace both the seals (on each end) as well as the clutch pushrod felt. Check the clutch slave cylinder too as these have been known to leak.
BMW updated the input shaft seals a while ago, so once you get the new seals CORRECTLY installed your problem should go away.
BTW, was the clutch done at 15,000 by an authorized dealer?? If so, there should be some warranty as BMW gives a two year warranty on repairs done by authorized dealers. If the clutch disc is worn out due to abuse, then that is a different story. Might be wise to investigate if you are entitled to some warranty coverage due to the leaking seals.
Oct 19, 2010 | 2007 BMW R 1200 GS Adventure
My maytag neptune tl leaks from the bottom while it washes MODEL #FAV6800AWW it leak about two to three cups of water for each load,about one drop per second.
Possible Tub Seal leak, leak from Outer Tub, Sump Cap, Drain Pump, Drain Line.
You need to pull the front cover off the machine and ID the leak source. If there wash water over the Clutch Pulley I would suspect a Tub Seal issue.
You can't link to the Service Manual form this site.
Google Maytag Neptune load unbalance and see if you can find support for the Service Manual.
Oct 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
422 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
