Mitsubishi 6500 Rear Projection TV won't turn on after power outage (Black Out). Green light is flashing on front and I have tried the reset per the manual. Please help!!
  • tom7571 Feb 01, 2010
    The model number is WS 65909, S/N 102292
    Your are awesome!
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
What is model number of this set?
It will begin with WD, WS, WT, VS etc.
SD TECH
Posted on Feb 01, 2010
  • SD Tech
    SD Tech Feb 01, 2010
    There are only two possible reasons for this:
    This model uses a receiver called a DM board----it is the large metal box on the left as you look from the back of the set; these sets have a history of four capacitors puffing up inside that unit. They are part of a standyby power supply for the DM unit-----there are places on the net that sell a kit with the caps and two fuses there.
    The way this works is if power is removed and then returns the green light means the DM is booting up just like a computer. If there is a problem the green light just keeps blinking. Chances are that when you lost power and it returned something on the DM got taken out.
    The unit is no longer available from Mitsubishi but can be sent out to a national company called PTS electronics for repair/rebuild----you can contact them via the net or get their 800 number if you Google them.
    The only other possible solution is sometimes the reset button on the front of the set goes bad. To discover if this is the problem or not----remove the front speaker grill (it will pull out) and remove the inspection plate behind it.
    You will notice one or two groups of wires coming down from the front keyboard; follow them to the right and unplug the two (usually two) plugs that connect them to the main chassis---you will then be able to try after waiting 70 seconds to turn the set on with the remote---if it comes on the reset button is bad---if it does not-----THE DM UNIT IS BAD.
    70 seconds is the normal time for the DM to boot up.
    Let me know if you have questions or need advice.
    SD TECH
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi DLP 60" - power
Unplug the television, let it sit for an hour an try to plug it back in. That should resolve the problem. if it still flashes green after you do this, use the "reset" button again. Let me know if that works.
Nov 23, 2010 | Televison & Video
The green light on the front panel is flashing but
Try website Tvrepairworld.com to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV does not power on
Ur power ic inverter board is dead.U need a neww one.
Aug 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Lamp light flashing green continually after power outage. have hit reset button, unplugged tv, nothing works
the timer light will continually flash green.on the dm pcb and fmt pcb you have 4 capacitors
that pooch out.replace the 4 capacitors on both boards.will require a tv professional to do
this.
Jul 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
