Question about Amana ARS2661B Side by Side Refrigerator
Freezer not freezing. It works for several days then thaws out. I think it might be the defrost thermostat getting stuck. Is that where you would start?
  • 105 Answers
Best off to call a reliable service company such as Sears. It could be the defrost thermostat or the defrost termination thermostat or the defrost heater.
Posted on Feb 01, 2010
All my food thawed in my freezer. Is it just defrosting or is it broken?
Most newer freezers have self defrosting. But it will not thaw out the food at all. For it to thaw completely in 1 day, the compressor did not come on at all. I would first check the fuse or circuit breaker in your home. Many different issues could cause the same result of the freezer not getting cold at all. Defective thermostat, defective compressor, refrigerant leak or loose wiring at connection points. It could possibly be stuck in the defrost mode too.
Oct 30, 2015 | Refrigerators
Refrigerator not defrosting?
you are describing a problem that has 2 causes at the same time;
if your drain tube is freezing up, you usually have a defective drain heater, easy. to replace.
the warming up is due to accumulation of frost on the evaporator.
the defrost system contains 3 components - defrost heater, defrost thermostat and defrost timer. First try to advance the timer into the defrost cycle, if you hear crackling in the freezer and it start to defrost, you have a bad timer (very common problem) if not, you must check the defrost heater and thermostat or just replace both...
good luck
Dec 21, 2014 | Refrigerators
Freezing up in duct system frig part
Have you checked the heater/defroster element within the freezer? It may be related. When mine failed I was doing the defrosting with a hair blower. Over time (several days) the frost would build up on the freezer coils and the air couldn't flow as it should....so the thermostat wasn't getting cooled enough and it relayed the information to the cooling system, causing the frige to run all the time. Since it was clogged with frost, the frige was constantly trying to cool itself and the frost problem would get so bad that things in the freezer began to melt due to a lack of cold air circulation. After the heater/defroster element was replaced, frost would melt during the defrost cycle (as it should) and airflow/circulation was restored, allowing the thermostat to be cooled properly. Then the freezer coil was able to 'rest' when it should instead of constantly freezing to meet the demand for cold air in the frige. Hope this makes sense...and helps solve your issue.
Apr 11, 2014 | Kenmore Refrigerators
My fridge/freezer defrost itself last night and the freezing and frigde temperatures went low and my frozen food was all thawed
manually rotate your defrost timer maybe it stuck up and the contact was on the defrost heater. adjust your thermostat setting to coldness then observe unit.
Mar 05, 2011 | Refrigerators
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Any possibility you can help troubleshoot a larger upright freezer? Our freezer is 3 years old. It sounds like it is working -- I can feel cold air and hear it humming, but as of yesterday it stopped...
Assuming the thermostat is set to call for cooling (sometimes they get bumped), check the condenser coils, fan, etc for debris build up and clean as needed.
Is the freezer frost free? If so, it's possible the defrost timer is stuck in defrost. There should either be a mechanical timer or it could be electronic these days. Check for bad connections or any obvious signs of damage (burn marks)
Make sure the freezer door closes tightly
Jul 25, 2009 | Haier 3.6 cu. ft. / 102 liter Chest...
Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Apr 22, 2009 | Refrigerators
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Hot fridge - cold freezer
Hi. I reccommend you replace the defrost timer and bimetal thermostat. The bimetal thermostat is located on the evaporator coil. The bimetal thermostat is the most common failure. Good luck, Mack
Aug 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer not getting cold to freeze
ok if this fridge uses a defrost timer, it's probably stuck on defrost or the defrost thermostat is faulty also check the number on your thermostat it its on a low number the fridge won't cool properly also a refrigerant leak could be suspected.
May 17, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Amana ARS2661B Side by Side Refrigerator Logo
119 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
