Question about Kenmore 64802 Top Freezer Refrigerator
Water leaking from under fridge - Kenmore 64802 Top Freezer Refrigerator
  • 105 Answers
Sounds like either the drain hose is plugged or the bottom water tray is cracked. Best off to call a reliable service company such as Sears.
Posted on Feb 01, 2010
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
We have a leak and find a puddle under the fridge. The input water lines at the back of the fridge don't appear to be leaking.
there is usually a pan under there to collect water when it defrosts and lets water evaporate perhaps your pan got thrown away .
Nov 19, 2015 | Kenmore Refrigerators
Stop water under fridge
I'd go to the manufacturer of the appliances website. There you might be able to contact customer service or look through the original owner's manual. That might help.
Nov 19, 2014 | Refrigerators
Leaking under neath front of refrigerator
Usually any defrost water sits in a plastic pan and evaporates away in normal operation. If the pan becomes brittle it cracks and leaks water. Pull the fridge out and look on top of the black pot (compressor) Is there a plastic drain pan sat on top of it?
Sometimes if the fridge is working hard a lump of ice can form on the pipework going back to the compressor which melts causing some water at the front of the fridge.
Lastly, the insulation under the fridge may have broken down, allowing condensation to form and drip. If the drain was blocked, the water would be inside the fridge, not underneath.
Apr 20, 2012 | Kenmore Refrigerators
It leaks water from underneath
If the water is coming out from under the fridge and you have a water dispenser or automatic ice maker, then I would suggest that you pull the fridge out from the wall and check the water tubing going to the back of the fridge. The tubing is connected with a compression fitting (a special nut that compresses the tubing to the fridge. There may also be a few more pieces of tubing on/in the back of the fridge with these fittings. Place you fingers on each fitting to see if it is loose or wet. If you find a wet or loose fitting, take some pliers and tighten it (snug it up, but not too tight because you can damage the fitting. Dry up the water. Watch the fridge for a while to make sure the leak is stopped. If you can't get it stopped, or if it gets worse, you can cut off the water (there should be a valve under a cabinet next to the fridge, or under your sink). You can get a replacement fitting at Lowe's2_bing.gif and they can tell you how to install it if necessary. If you have water pooling under your fridge and it goes up to the wall, then you should check on the other side of the wall for water also. This happened to our fridge, but we did not see the water in front of the fridge because it ran to the back of the fridge and under the wall into our carpet on the other side. Wet carpet is how we discovered the problem.
May 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking under fridge
Check your hose for your water/ice dispenser.
Nov 07, 2009 | Maytag MZD2766GES Side by Side...
Rs2556sh model leakes water under fridge when ice maker cycles
If there was water in the water line it could have split. Check on the back where the water line goes from the inlet valve to the ice maker.
Oct 01, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge is leaking water
Probably one of the plastic tubes under the refrigerator is leaking.
Apr 04, 2009 | Refrigerators
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fridgidaire Gallery Series Side by Side Refridgerator
"jennycub" sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. very common problem( easy to detect. water on the floor of freezer compartment) as far as the other posting by" humblerumble", ive seen where the drain tube under the refig has pushed a hole into the drain pan under the refrig, in which case it will only leak after a defrost cycle, with the kickplate removed grab a flashlight and look under the unit for the drain pan as you pur water into the back of the freezer sect to trace water flow
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore 64802 Top Freezer Refrigerator Logo
85 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
